1974 cj 5 - JeepForum.com
post #1 of 7 Old 01-13-2003, 08:41 PM Thread Starter
cherokeenation
1974 cj 5
Hey all, I was just looking at picking up a 74 cj 5 and had a few questions. It seems that everything for aftermarket parts deals with 1976 and newer. Will I have trouble finding parts for this 1974? If so I will wait, but it is too sweet a deal to turn down. If anyone has info I'd much appreciate since I will be looking at it tomorrow night.
cherokeenation is offline
post #2 of 7 Old 01-13-2003, 09:30 PM
cj5mudman4x4
get it.. u cant find parts for a 73'.. trust me.. everything i want is from 74 up... and u can always get a vintage cj catalog from www.4wd.com that is 4wd hardware.. that place is great..get a cj/wrangler catalog and a vintage.. and then u can get anything ur heart desires..
good luck
buy the jeep if its a good deal, Jeeps change lives
1973 CJ5
258ci I6 rebuilt. bored .40
Painless wiring harness
INDEPENDENT OFFROAD member Bowling Green, Ky
cj5mudman4x4 is offline
post #3 of 7 Old 01-13-2003, 09:43 PM
CSP
Say what???? The only thing different on a '73 and '74 are the body mounts and even they can be interchanged with very little work. Virtually everything from '72-75 is identical. What exactly do you want that you are believing is only available for '74 and up?
Cherokee a lot of the '76 and up parts that you see in the catalogs will also fit '72-75. They are listed as '76 and up in many cases because they aren't exactly the same as pre-76 and worthless to someone looking for an exact part.
For example 4WD Hardware lists its battery trays as '76-86. They will fit perfectly on any '72-75. The difference is the '76-86 have an additional support brace that wasn't there in '72-75. All other support braces and bolt holes line up perfectly. You will need to drill one hole in the firewall of a '72-75 if you want to utilize the extra brace. That's just one example but you do have to be familiar with what fits and what doesn't before ordering.
CSP is offline
post #4 of 7 Old 01-13-2003, 09:51 PM
cj5mudman4x4
sry CSP, i didnt mean that literally... i meant that when ever i looked for something i always got left a yr behind...
anyways, i meant it sarcastically
sry to fire u up
1973 CJ5
post #5 of 7 Old 01-15-2003, 05:50 PM
fuzz401
1978 CJ7
cj-5
the spring pad on the rears are in fartherthe cjs after77 the springs are wider the rear is a dana 44 flanged axel too used from 74 to 76 i think any rear u put in from other cj you will have to make new spring perch for it
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #6 of 7 Old 01-15-2003, 06:21 PM
Tuts
You'll probably find out that the main reason that you cant find things like a hardtop because the windshield is different on the 75 on down. I too have a 74 CJ5. I wish it was a 76 but whatever. If you dont mind not being able to find a hardtop because they are rare and don't make them anymore. Also, I havent been able to find lightbars either and you can forget about a roof rack. Oh well. It's still a CJ but if it doesn't have a V8 i'd suggest looking for another jeep.
Tuts
I am Tuts.
Jeep pics up and running.
Blue Jeep Club Member #35
Tuts is offline
post #7 of 7 Old 01-15-2003, 07:50 PM
CSP
Re: cj-5
Nope. The wider frame began in '76 so the spring perches being wider also started in '76. The Dana 44 flanged rear axle actually was used from mid-70 through '75. The difference being the mid-70 to 71 has an offset diff.
CSP is offline
1974 CJ5 w/ 304 -- Upgrades? emeraldcite Jeep CJ Forum 15 09-12-2015 04:17 PM
1974 CJ5 Questions JCook5003 Jeep CJ Forum 6 02-27-2009 04:23 PM
1974 CJ5 Value goingtopless Jeep CJ Forum 16 01-01-2008 07:07 AM
1974 J30 omanalansanjr Jeep CJ Forum 0 10-02-2007 01:48 PM
1974 CJ5 dashboard and 4WD zulugrid Jeep CJ Forum 2 04-01-2007 08:18 PM
