1973 CJ5 Trail Rig/Hunting Rig Build - Page 8 - JeepForum.com
post #106 of 113 Old 12-08-2013, 09:24 AM
JeepHammer
Running On Empty...
1973 CJ5
No such thing as a 'Free Jeep'...
They are like 'Free Dogs'! Cost you out the wazoo before it's over!
Good work!
I feel your pain, I got a 'Cheap' '73 CJ-5, nothing but wiring glitches, rust, frame cracks, Rust, PO screw ups, RUST, water damage, RUST, you get the idea...
Draw bar! Love draw bars! Makes me think I'm on the tractor!
Windshield clamps that don't clamp...
Heater & Defroster controls that don't hook up to anything (don't think they did from the factory! ;( )
The motor does make a most annoying noise, which takes you mind off the cold a little...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #107 of 113 Old 12-29-2013, 05:19 PM Thread Starter
Lifted96ZJ
1973 CJ5
Got a lot done Friday installing everything I received for xmas
Removing the old crap
Goodbye old, rusted tank
Goodbye old, tired dizzy
Goodbye rusted, busted exhaust
New exhaust flanges
Flanges mocked up
New mufflers mocked up. Still need to finish welding everything and finish the exit location
New HEI Dizzy and 8mm pkug wires
Installing the dizzy
Finished product. I still need to clean up the wires
New tank
Tank installed. Still need to wrap up the filler neck
Overall, very happy right now. Jeep is running 100 times better, sounds better and I can fill the tank above 5 gallons again lol
Build Thread
http://www.jeepforum.com/forum/f8/1973-cj5-trail-rig-hunting-rig-build-1403107/
Lifted96ZJ is offline
post #108 of 113 Old 12-30-2013, 07:23 AM
Rumpeltiltskin
1957 CJ6
I hope you plan on tucking those mufflers up higher. if you plan on going offroad at all they will be smashed pretty easily. There should be enough room (barely) to get the pipes above the trans crossmember.
Build thread-1957 CJ6 4.3 swap!
2000 WJ Limited bone stock (Wifes rig)
Rumpeltiltskin is offline
post #109 of 113 Old 12-30-2013, 10:23 AM Thread Starter
Lifted96ZJ
1973 CJ5
Yeah they are only mocked up right now. Plus I don't plan on taking it on any really crazy trails other than the rubicon. It's mainly a hunting rig
Build Thread
post #110 of 113 Old 01-07-2014, 09:22 AM Thread Starter
Lifted96ZJ
1973 CJ5
Finished putting the filler neck on the new tank yesterday. Then I finished tucking my exhaust as high up as it could go. Then I moved on to fine tuning the new distributor. Only to finally find my jeep flooding again. Found the real issue. White smoke only from one side of the exhaust.
The one thing I never did was tear down the upper half of the motor and replace head gaskets and the gaskets on the intake manifold. So that's happening next. Plus it will be a good time to re-seal all of the valves because I'm sure they are leaking slowly also. I knew I should have done this when I originally had everything torn down. That's what I get for hoping all would be good. Now I just need to make sure it didn't cause any other real damage that would require a full rebuild. I also know a guy that has a 304 long block with low miles that is willing to either give it to me for free or sell for cheap. If I can get my hands on that I might just rebuild it and toss this motor out the window.
Ahh the perks of owning a jeep!
Build Thread
post #111 of 113 Old 04-08-2014, 07:39 PM Thread Starter
Lifted96ZJ
1973 CJ5
Finally worked on the jeep a little yesterday. Got the carb off and intake manifold off. Only to find small deposits of oily water under the valley pan. So my prediction could be true. Could just be a head gasket issue but my motor could also be close to toast if water has been getting into the piston chambers. Guess I'll find out more when I get the heads off
Build Thread
post #112 of 113 Old 07-14-2014, 02:43 PM
Mongoos4e
1979 CJ5
I've got a similar jeep, this thread gives me lots of ideas where to start and how to go about doing it.
Mongoos4e is offline
post #113 of 113 Old 07-19-2014, 11:41 AM Thread Starter
Lifted96ZJ
1973 CJ5
I've barely been able to touch this thing over the last few months. The heads are currently off waiting to go to a shop and I'm in the process of disassembling the bottom end for a rebuild
Build Thread
CJ owner's who prefer hunting and shooting to trail riding... 243 Jeep CJ Forum 939 01-11-2017 06:24 AM
CJ5 Trail rig Build w/ Pics crzdmnky Jeep CJ Forum 84 04-21-2011 04:22 PM
1973 Cj5 Marinehorne Jeep CJ Forum 24 02-10-2011 10:10 PM
Drivetrain Build Advice Trail and Second vehicle use, for now Woolys_CJ7 Jeep CJ Forum 1 10-20-2009 01:33 PM
Trail CJ build ?'s this is long but I like to get others ideas. texascj77 Jeep CJ Forum 13 09-20-2007 10:21 AM
