1973 CJ5 Trail Rig/Hunting Rig Build - Page 5 - JeepForum.com
post #61 of 113 Old 03-24-2013, 09:09 PM Thread Starter
Lifted96ZJ
1973 CJ5
Painted the firewall flat black
Started stripping and painting the motor parts that I want to clean up
Everything that is getting cleaned and painted (valve covers and oil pan too but they are still on the motor)
Most things were just disgusting
Teaser shot
Clutch fan, alternator bracket, pulleys and power steering bracket will all be black. Water pump, valve covers, air cleaner, oil pan will all be grey
Build Thread
http://www.jeepforum.com/forum/f8/1973-cj5-trail-rig-hunting-rig-build-1403107/
Lifted96ZJ is offline
post #62 of 113 Old 03-24-2013, 09:51 PM
sanctified
I'm a total noob and am impressed with your build. I just bought an 83 CJ7, am on a serious budget and want to prep it for a cheap paint job. Could you explain what you did to prep yours for paint? Other than your weld patch job did you hit it with a wire wheel? Just sandpaper? Thanks.
sanctified is offline
post #63 of 113 Old 03-25-2013, 06:11 AM
RDH
Subscribed. Sanctified, you could probably get away with a couple red scotchbrite pads and wetsanding the whole thing. Wash it real good with dish soap and water, let it air dry and spray on whatever paint you want to use.
1978 CJ7: 304, 3Spd, AMC 20 Rear, Thrush Welded Mufflers W/ Turndowns, Unknown Front, Worn out Dana 20 case
RDH is offline
post #64 of 113 Old 03-25-2013, 09:04 PM Thread Starter
Lifted96ZJ
1973 CJ5
Slowly putting pieces back on after paint
Starting to look like a motor again
Build Thread
post #65 of 113 Old 03-25-2013, 09:07 PM Thread Starter
Lifted96ZJ
1973 CJ5
I hit it with 80 grit on my air sander. It's not technically ready for color yet. Still needs some areas evened out but it's close. Going to hit the rough areas with a flap wheel to get down to bare metal
Build Thread
post #66 of 113 Old 04-05-2013, 09:52 PM Thread Starter
Lifted96ZJ
1973 CJ5
Engine is almost fully buttoned up!
Build Thread
post #67 of 113 Old 04-15-2013, 07:55 PM Thread Starter
Lifted96ZJ
1973 CJ5
Wrapping up the engine bay!
Oil pan stripped, cleaned and painted
Installed with new gaskets
Didn't end up replacing the entire steering box, instead I got lucky and found that one of the lines were broken so I replaced it
Everything re-installed, gaskets all replaced and all fluids filled. Ready to run again, just needs the new wiring harness installed
Build Thread
post #68 of 113 Old 04-16-2013, 06:12 AM
RDH
Looking good. You got lucky with the steering box, mine leaks like a sieve. Your Jeep is going to look like a new penny when you get done.
RDH is offline
post #69 of 113 Old 04-16-2013, 06:53 PM Thread Starter
Lifted96ZJ
1973 CJ5
I don't think it will look quite that good but it will definitely be worlds better. Thanks for the support!
Build Thread
post #70 of 113 Old 04-17-2013, 07:12 AM
Rumpeltiltskin
1957 CJ6
A free jeep only needing 1 rust patch? Jealous
Build thread-1957 CJ6 4.3 swap!
2000 WJ Limited bone stock (Wifes rig)
Rumpeltiltskin is offline
post #71 of 113 Old 04-17-2013, 09:00 AM
Jack718
1972 CJ5
I'm not sure if you said this somewhere in the thread but I saw that you were going to fab some seat frames. I need to do the same for my jeep. It's also an Intermediate model and was curious what you were going to do.
Thanks
Jack718 is offline
post #72 of 113 Old 04-17-2013, 07:14 PM Thread Starter
Lifted96ZJ
1973 CJ5
I cut holes in the fenders, bed and put a bar across the from for the seats. I'll post pics when the seat mounts are finalized
Build Thread
post #73 of 113 Old 04-28-2013, 07:55 PM Thread Starter
Lifted96ZJ
1973 CJ5
Getting more work done, one portion at a time.
New grille, stripped, painted and installed
Lighting and radiator installed
Interior bed-lined and dash mocked up prior to paint
I need to get the dash ready this week and then it's time to start wiring it up. Anyone that has done the ezwiring kit send me a pm on where to start! LOL I feel lost when it comes to wiring. Should I keep all the old connectors from the stock harness so everything plugs right in?
Build Thread
post #74 of 113 Old 05-05-2013, 09:06 PM Thread Starter
Lifted96ZJ
1973 CJ5
Had some time to get a few more small things done
Got the inside and underside of my fenders cleaned, painted and re-installed
Looks an engine bay again
Didn't get any pics during the process but they turned out great. Body paint will be coming soon
Painted my dash and reinstalled it
Started to lay out my harness and figure out how and where I'm going to mount it
Things are starting to come along nicely!
I might just prime the entire thing again and drive it like that for a bit while I figure out the final color and plus it leaves me time to finish my tube fenders before final paint
Build Thread
post #75 of 113 Old 05-18-2013, 10:17 PM Thread Starter
Lifted96ZJ
1973 CJ5
Got quite a bit of work done over the last 2 weeks. All of the engine wiring is complete. She runs again! Had an oil pressure issue for a few day so I bought a repair kit for the oil pump and packed it with petroleum jelly and solved that issue. Running pretty smoothly now.
Running again!
My wiring mess I need to clean up
Dash mounted and gauges mocked up
Seats mocked up
Seats mounted and front half of roll cage bolted in
Almost ready to drive!
Everything is coming along really fast now. I need to finish up the rest of the wiring and clean it up and then it will all be cosmetic stuff until I can afford to go through all of the suspension and running gear
Build Thread
CJ owner's who prefer hunting and shooting to trail riding... 243 Jeep CJ Forum 939 01-11-2017 05:24 AM
CJ5 Trail rig Build w/ Pics crzdmnky Jeep CJ Forum 84 04-21-2011 03:22 PM
1973 Cj5 Marinehorne Jeep CJ Forum 24 02-10-2011 09:10 PM
Drivetrain Build Advice Trail and Second vehicle use, for now Woolys_CJ7 Jeep CJ Forum 1 10-20-2009 12:33 PM
Trail CJ build ?'s this is long but I like to get others ideas. texascj77 Jeep CJ Forum 13 09-20-2007 09:21 AM
