1973 CJ5 Trail Rig/Hunting Rig Build - JeepForum.com
post #1 of 113 Old 08-08-2012, 07:32 PM Thread Starter
Lifted96ZJ
1973 CJ5
I want to document the small build that I'm doing on a 1973 Cj5 that I received for free. Of course, we always want to budget our builds and keep them cheap but we all know that rarely happens. My goal is to keep my build under $4k total. We'll see how that goes....
How I first received her, after sitting for 5+ years and not running
After a pressure wash, turns out she was white lol
Next I got a windshield and roll bar for free dollars. Just fitting the roll bar at this point
Got the roll bar bolted in and a test color spray canned on
Also, it turns out I got lucky and it already had 4" lift springs installed and also has the stock 4.27 option in the rear.
Lifted96ZJ is offline
post #2 of 113 Old 08-08-2012, 07:35 PM Thread Starter
Lifted96ZJ
1973 CJ5
All of the above work was done in a 2 week time span. Then I began looking on CL for good deals for parts I needed. First was these set of 33" pro comp mud terrains I found with 40% tread left for $125 (Keep in mind this vehicle will never see asphalt)
Then I traded an old laptop I had sitting around for these seats. Perfect colors for the setup I have in my mind
Test fitting the seats
post #3 of 113 Old 08-08-2012, 07:39 PM Thread Starter
Lifted96ZJ
1973 CJ5
The seats aren't mounted yet because I need to fab a mounting bracket for the driver's side but they will be in the next few weeks.
The last 2-3 weeks I've been focusing on getting the old 304 to run again. Started with draining everything and refilling all the fluids in the engine bay, replacing the cap, spark plug wires, rotor, cap and points. Got a brand new radiator. Also dropped the tank, replaced the fuel sending unit, cleared out all the fuel lines and replaced the carb with rebuilt 2 bbl MC2100. (I have no pics of any of this)
I got her to finally turn over but had some issues with spark last week. Then we fixed the wiring and got it to start and idle. Now I just need to replace the plugs and mess with the timing and she'll be done in the engine bay for now.
It's not much right now but it's a start and I've a little around $500 in it so far. I pulled the black wheels shown in the first few pics and repainted them but I have yet to mount the 33s on them yet. That will be happening next week
post #4 of 113 Old 08-08-2012, 07:46 PM Thread Starter
Lifted96ZJ
1973 CJ5
Wheels painted flat black
Valve covers and air cleaner cover painted flat black
post #5 of 113 Old 08-08-2012, 08:05 PM
BradWilson101
1975 CJ5
Very nice. Keep up the good work
75 CJ-5 with 76 glass tub. 350 sbc with Edelbrock 600cfm, SM465, D20, D44 w/ 3:73, D30 w/ 3:73, Novak Hydro Clutch Convo. Turned into a frame off resto so it's still in progress.
BradWilson101 is offline
post #6 of 113 Old 08-08-2012, 08:44 PM
draperjojo
1946 CJ2A
draperjojo is offline
post #7 of 113 Old 08-08-2012, 09:41 PM
War_Eagle34
1980 CJ7
Ver interesting thread so far. Will be following.
War_Eagle34 is offline
post #8 of 113 Old 08-08-2012, 09:43 PM Thread Starter
Lifted96ZJ
1973 CJ5
Originally Posted by draperjojo View Post
Nice! Thanks for the link!
post #9 of 113 Old 08-08-2012, 09:44 PM
cody4359
1987 MJ Comanche
good score on the seats
cody4359 is offline
post #10 of 113 Old 08-15-2012, 10:09 PM Thread Starter
Lifted96ZJ
1973 CJ5
Got my 33s mounted today so I slapped them on and I took a few more pics of the entire Jeep. Gives you a much better idea of how much work needs to be done to clean it up
Build Thread
http://www.jeepforum.com/forum/f8/1973-cj5-trail-rig-hunting-rig-build-1403107/
post #11 of 113 Old 08-23-2012, 10:34 AM Thread Starter
Lifted96ZJ
1973 CJ5
Threw in a stock distributor with vac advance along with a new cap, rotor, points and condenser. Made a WORLD of difference in the way it runs. Smooth as a top now. Also picked up a new battery yesterday.
Tested the alternator and it's bad so I ordered a replacement, should be here tomorrow.
Went to fix my exhaust leak at the manifold collector and it looks like it's damaged pretty well so I tightened it up the best I could for now and it will have to wait until I order a set of headers.
And I drove it! Plopped in a 5 gallon bucket on the floor and put it in gear and drove it a few backwards a few feet and forwards a few feet. It wasn't a complete driveline functionality test because it has no brakes right now. I've everything to replace the entire brake system waiting to go on but haven't gotten there yet. She should be mechanically buttoned up in the next month or so then it's on to cosmetics
Read more: http://www.jeep-cj.com/forums/f98/19...#ixzz24O6g02x2
Build Thread
post #12 of 113 Old 09-13-2012, 08:28 PM Thread Starter
Lifted96ZJ
1973 CJ5
Got a good amount of work done over the last few weeks.
Fixed my oil leak by replacing the oil pressure line. It was plastic and it had a hole in it so I switched it over to copper.
Picked up the other half of my roll cage that matches the one that I already have.
Got a new bumper, mounted it and painted it. Started drilling my winch plate to mount it.
Did some sanding in some areas on the body and the roll cage that had collected a touch of rust.
Fixed my exhaust leak
Replaced my rear differential gasket
And yesterday I started to tear down the rear brakes, I had to beat the drums off which took about 2 hours. Everything inside was rusted and pretty much broken. Drums couldn't be turned so I had to order new ones too. Missing a few small brake parts that are on order then as soon as I get them I'll be slapping them on
Getting close to all of the mechanical items being done. Then I'll be going through all of the wiring and gauges. Then it's on to bodywork and paint!
Build Thread
post #13 of 113 Old 09-14-2012, 01:36 AM
CJ258
1974 CJ5
Now would be a good time to rewire it. That model doesn't have a fuse box. My '74 had brittle wires with inline fuses and shorts everywhere. Then you could upgrade the headlight wiring to run relays for some real lights. I peeled the wires from the headlights back about a foot and the copper was black.
CJ258 is offline
post #14 of 113 Old 09-14-2012, 05:37 PM
TmasCJ5
1977 CJ5
Looks like a fun project, will follow your posts. Are you putting stock brakes back on it? just curious, i've been gathering parts to covert my '77 to a rear-disc setup.
TmasCJ5 is offline
post #15 of 113 Old 09-15-2012, 10:12 AM Thread Starter
Lifted96ZJ
1973 CJ5
I'm undecided on whether I want to purchase a new wiring harness or just redo all of the current wiring. I kind of like that fact that the pre 75 don't have fuse blocks and are solid wiring. It will all come down to funds.
Build Thread
CJ owner's who prefer hunting and shooting to trail riding... 243 Jeep CJ Forum 939 01-11-2017 05:24 AM
CJ5 Trail rig Build w/ Pics crzdmnky Jeep CJ Forum 84 04-21-2011 03:22 PM
1973 Cj5 Marinehorne Jeep CJ Forum 24 02-10-2011 09:10 PM
Drivetrain Build Advice Trail and Second vehicle use, for now Woolys_CJ7 Jeep CJ Forum 1 10-20-2009 12:33 PM
Trail CJ build ?'s this is long but I like to get others ideas. texascj77 Jeep CJ Forum 13 09-20-2007 09:21 AM
