1973 CJ5 throwout bearing lever question - JeepForum.com
post #1 of 9 Old 08-18-2013, 04:51 PM Thread Starter
Lifted96ZJ
1973 CJ5
When I re-installed my trans/transfer case, I had the throwout bearing lever attached to the throwout bearing and somewhere during the installation the lever fell off and I can't get it situated around the throwout bearing while everything is installed. Any tips to fix this or do I need to pull everything again?
Build Thread
http://www.jeepforum.com/forum/f8/1973-cj5-trail-rig-hunting-rig-build-1403107/
Lifted96ZJ is offline
post #2 of 9 Old 08-18-2013, 06:36 PM
texasdave
texasdave's Avatar
1980 CJ7
Did you attach the spring?. If the spring isn't installed then you will have to take the engine and transmission apart. You might be able to get your hand in the starter hole
texasdave is online now
post #3 of 9 Old 08-18-2013, 06:43 PM
OleBlue73
1973 CJ5
And/or take the inspection plate off the front/bottom of the bell housing.
1973 CJ5, 304, T15, D20
2009 JKU, Rubicon
2005 TJ, X, 4.0, 6 speed
OleBlue73 is offline
post #4 of 9 Old 08-18-2013, 06:48 PM Thread Starter
Lifted96ZJ
1973 CJ5
Inspection plate is off right now. The only thing keeping it from turning and sliding over the throwout bearing is the small cylinder that holds the clutch ball. I think I'm going to have to pull the trans again
Build Thread
post #5 of 9 Old 08-18-2013, 06:59 PM
LumpyGrits
Back the tranny mounting bolts off about 1/2" and slide the tranny back.
You might be able to slide the fork over the BB in the b'housing. Does sound like you left the spring off the fork.
Good luck,
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #6 of 9 Old 08-18-2013, 07:10 PM Thread Starter
Lifted96ZJ
1973 CJ5
Yeah the spring wasn't attached correctly and it fell off
Build Thread
post #7 of 9 Old 08-18-2013, 07:14 PM Thread Starter
Lifted96ZJ
1973 CJ5
I only need about a half an inch or so to get it in so I may try that technique
Build Thread
post #8 of 9 Old 08-18-2013, 07:21 PM
LumpyGrits
With the spring NOT installed. Your goanna have to put the box, and do it 'rite'.
LG
post #9 of 9 Old 08-21-2013, 09:35 AM Thread Starter
Lifted96ZJ
1973 CJ5
Fixed the clutch issue last night. Unbolted the bellhousing, dropped the trans about 2 inches and pulled it out about a half an inch. Attached the throwout lever and spring, slid the ball in and then reattached the bellhousing and everything was good to go. Replaced the trans/transfercase crossmember bolts with longer ones so I can attach a skid plate to them in the future.
Build Thread
