1973 CJ5 Steering Column - JeepForum.com
post #1 of 4 Old 01-28-2012, 06:08 PM Thread Starter
MSRIDER75
Guys,
I'm planning to rebuild the steering on my '73 cj5 and am trying to find an aftermarket or original column. Mine is currently retrofitted with something (not original) and has a small diameter steering wheel. As if the steering wasn't squirrly enough I was hoping to put the larger wheel back on to hopefully help some with controlling this manual steering beast as part of the overall upgrade. Any ideas on where to look other than a local scrap yard?? Been on most of the go-to sites as well as ebay and can't seem to find what I'm looking for.
MSRIDER75 is offline
post #2 of 4 Old 01-28-2012, 09:14 PM
taylorjb
1973 CJ5
Are you looking for just the "school bus" wheel, or the whole column?
Might be a good time to go ahead and upgrade to power steering...it's not a hard swap, you can reuse your current bracket for the box.
Good luck.
JT
Denver, CO
taylorjb is offline
post #3 of 4 Old 01-29-2012, 06:56 AM Thread Starter
MSRIDER75
Really just looking for the wheel, but because the adapter has been changed at some point I was told I'd need the cloumn that would fit the larger wheel. The one I have now has a octaganal (8) sided end piece. I think the larger school bus wheels (or at least the one I found) actually has the vertical grooves that slips down over the column end - also with grooves. If what I just said makes any sense......
post #4 of 4 Old 01-29-2012, 07:13 AM
Pathkiller
1974 CJ5
The earlier style "school bus" wheel won't work on a later style Saginaw (GM) column. If your column has been swapped the wheel won't work on it, the diameter of the shaft and the splines are different.
If you're looking for the entire column, the DJ postal Jeeps and Jeepster Commando both used the same, or a similar type of column.
And swapping to power steering has nothing to do with the column. You can use any type of column you want as long as you use a lower steering shaft that matches the steering box.
Pathkiller is offline
1973 CJ% Steering Question hoagiedog Jeep CJ Forum 0 08-15-2011 08:30 AM
Steering column options for column mounted shifter... HeepToJeep Jeep CJ Forum 7 06-01-2011 06:59 AM
1973 CJ5 Power Steering Upgrade xport Jeep CJ Forum 9 08-02-2010 09:13 PM
1973 power steering conversion sully1973 Jeep CJ Forum 4 12-17-2009 11:53 AM
1973 CJ5 tilt steering column help!! SoCalinIt Jeep CJ Forum 2 03-23-2009 01:09 PM
