1973 CJ5 (Carburator & Fuel Lines) - JeepForum.com
post #1 of 3 Old 09-26-2012, 06:40 AM Thread Starter
lucany
1973 CJ5
Hi Folks new on here...i have a CJ5 year 1973 under restoration. I am looking for suggestions on
- Where and which Fuel Lines shall i buy (need replace the old ones...all I can find are fuel lines for a CJ5 1976 model or older......will those fit?)
- What Carburetor will be a good upgrade for this car/engine? 1973 258 4.2L ? i want to stay in the $ 200 ballpark price...any idea where is the best buy option online?
thanks for all help
lucany is offline
post #2 of 3 Old 09-26-2012, 07:35 AM
FrnchDp
FrnchDp's Avatar
Greetings and welcome. Nice 5 you got there!
For the carb, I just upgraded to the M2150. I paid near 3bills for it, but it was completely rebuilt and came with all the parts/adapters. You can get those for much cheaper if you're willing to do the rebuild yourself.
As to the fuel lines, I didn't replace the entire system, but did replace the metal tubes that run from pump to carb. I used this place for those -> http://inlinetube.com/Preformed%20Li...s/ocatalog.htm
The other carb many will suggest will be the Weber, which, fully remanufactured will run in the 3-5 ballpark. I figure you'll want to be going the DIY rebuild, and my understanding is that either Motorcraft or Weber are fairly standard rebuild with cheap kits found at local parts stores
1986 CJ-7 - I6-258
2000 WJ Limited - V8-287
FrnchDp is offline
post #3 of 3 Old 09-30-2012, 07:52 AM Thread Starter
lucany
1973 CJ5
many thanks this is helpful!!!
lucany is offline
carburator , cj5 , fuel , fuel lines , gas mileage increase
cj5 brake lines and fuel lines question krisbodean85 Jeep CJ Forum 6 08-01-2012 08:10 PM
1973 cj5 fuel sending unit resnick717 Jeep CJ Forum 1 02-04-2012 04:14 PM
Best way to clean the fuel tank and fuel lines? Ryan546 Jeep CJ Forum 14 06-19-2011 08:29 PM
Installing Fuel Tank and Fuel Lines? How Hard? JeepFan07 Jeep CJ Forum 6 01-10-2008 06:49 PM
Weber 34 conv, nutter, Vacuum lines / Fuel lines valkadesh Jeep CJ Forum 29 06-11-2007 09:21 AM
