1972 cj5 fuel pump to carb what size double flair from pump? - JeepForum.com
post #1 of 5 Old 04-17-2012, 11:34 AM Thread Starter
chadco
1972 CJ5
I have the fuel pump for the 1972 and it is the one that points downward. It has the nipple, which I am assuming attaches to the fuel line from the tank and it has a double flair fitting that goes to the carb. I cannot find a good pic of how this attaches to the carb. Is it a double flair fitting to the pump and then to a rubber hose that then attaches to my carb? No one that I can find sells this double flair line from the pump. Oh yeah the engine is a 304. I could probably get this double flair at the parts store and make my own set up but I do not know what size the flair is. Anyone??
chadco is offline
post #2 of 5 Old 04-17-2012, 12:27 PM
CSP
It's not a double flare. It's a 3/16" inverted flare I believe, but it could possibly be 1/4".
CSP is offline
post #3 of 5 Old 04-17-2012, 01:07 PM
mopar346
Get the parts house to pull a fuel pump off the shelf and match the size, get a 3 foot steel brake line and bend your own. Once fitted cut to length and then use a double flare kit to "flare the end to hold a piece of rubber fuel line to the carb. Problem solved.
Careful your character's showing
mopar346 is offline
post #4 of 5 Old 04-17-2012, 03:26 PM
colojeepguy
1970 CJ5
Should be 5/16 double flare. You can get the steel line at a parts house & bend it yourself with a tubing bender.
colojeepguy is offline
post #5 of 5 Old 04-18-2012, 05:31 AM Thread Starter
chadco
1972 CJ5
Thanks guys for the good advice!!
chadco is offline
Pump to carb fuel line? 84jeepcj7 Jeep CJ Forum 10 01-15-2012 02:16 AM
not getting fuel into the pump, filter, or carb red82cj7 Jeep CJ Forum 1 07-23-2010 12:53 PM
carb 4.3l fuel pump question canuck2a Jeep CJ Forum 1 03-19-2009 07:03 AM
fuel pump or carb gublube Jeep CJ Forum 7 05-07-2007 12:10 PM
Fuel line - pump to carb - 258 Baloo Jeep CJ Forum 8 10-19-2006 09:33 PM
