1971 CJ5 Steering Box - JeepForum.com
post #1 of 8 Old 06-28-2013, 10:18 AM Thread Starter
Nuggie
Help guys my steering box needs replaced and I have not been able to find one anywhere. Any ideas would be appreciated. It is a 1971 CJ5 with a V6 three speed transmission. It is not power steering. Email me at ewaits@ec.rr.com
Nuggie is offline
post #2 of 8 Old 06-28-2013, 10:56 AM
fourbtgait
1930 MK Patriot
Check Redhead steering gears online in Seattle.
fourbtgait is offline
post #3 of 8 Old 06-29-2013, 05:04 AM
pritchaj2000
1972 CJ5
Does the '71 use the same box as the '72? I got a new one for my '72 from NAPPA.
Al Pritchard - 1972 Renegade | AMC 304
Build thread: http://www.earlycj5.net/forums/showthread.php?78780-1972-CJ-5-Almost-Restoration
pritchaj2000 is offline
post #4 of 8 Old 06-29-2013, 06:24 AM
colojeepguy
1970 CJ5
41-71 CJ's use a Ross steering box that is integral with the steering column-totally different from 72 and newer Jeeps.
There are rebuild parts available, but AFAIK no one sells rebuilt units.
The Ross box is a pretty primitive design dating back to the early 1940's. If you plan to keep the Jeep stock, it will be OK as long as all components are in good shape. If you plan a lift & big tires, you should consider a Saginaw steering swap-this is a common mod on early CJ's. Check out the pics here-
http://www.earlycj5.net/forums/showt...ease-add-yours!!
"It's better to have loved and lost, than to live with a psycho the rest of your life"
colojeepguy is offline
post #5 of 8 Old 06-29-2013, 09:35 AM
fourbtgait
1930 MK Patriot
Learn something everyday. I did not realize they used the same system for so long. The Redhead site list's from "70's" up, so I assume it's the saginaw box up. The link you provided is very insightful.
post #6 of 8 Old 09-09-2013, 11:19 AM
SalvagedManhood
1971 CJ5
Nuggie, how did things work out? I've got a 71 Cj5 withe the dauntless 225 V6 and the Ross box has started giving me some issues. Actually, the steering gets tight and when I try to force it I hear a loud creak in the steering column. Everyone says the box is wearing out... Not sure.
SalvagedManhood is offline
post #7 of 8 Old 09-09-2013, 11:25 AM
Mace350
I rebuilt my steering box with all new parts from Walks http://walcks4wd.com/fuel/fuel-pumps-kits-spacers.html
Here is the thread I used for the rebuild http://www.jeepforum.com/forum/f8/ho...1963-a-757027/
Mace350 is offline
post #8 of 8 Old 09-09-2013, 11:56 AM
brownbagg
1930 MK Compass
I replace everything onto Ross steering with Saginaw pulled off a 231 sunbird
brownbagg is offline
