1970 CJ5 rear axle shaft - JeepForum.com
post #1 of 8 Old 10-14-2013, 08:44 AM Thread Starter
TXHUNTER247
I have a 1970 cj5 with a v6 and have a bent hub in the rear. I have been told I can upgrade the rear hub assembly to a one piece shaft and hub. Is this true and what do I need to buy? Thanks
TXHUNTER247 is offline
post #2 of 8 Old 10-14-2013, 11:42 AM
colojeepguy
1970 CJ5
You need to find a rear axle out of a late 70 or 71 CJ.
Offset Dana 44 with 30 spline 1 piece shafts.
"It's better to have loved and lost, than to live with a psycho the rest of your life"
colojeepguy is offline
post #3 of 8 Old 10-16-2013, 09:33 AM Thread Starter
TXHUNTER247
Will the AMC 20 one piece shaft assembly not work? I'm trying to not have to buy a new axle.
post #4 of 8 Old 10-16-2013, 01:57 PM
CSP
No, it's a completely different axle. The diameter and spline count (your D44=19 spline, AMC20=29spline) where they engage the spider gears inside are different just for starters.
You don't have to buy a complete new axle assembly either. Just get a replacement for the two piece axleshaft. The Dana 44 two piece rear axle is much stronger than the AMC 20 and isn't nearly as prone to failure.
If there is anyone out there still making a one piece replacement for the D44, I can't find them. Moser or Dutchman may be able to custom make one for you.
CSP is offline
post #5 of 8 Old 10-17-2013, 11:26 AM Thread Starter
TXHUNTER247
Omix is saying they make one for a 1972-75 which are Dana 44. Shouldn't that fit?
post #6 of 8 Old 10-17-2013, 11:30 AM
dg6772
Best bet on fit would be to talk to supplier. If they have a tech line, use it. Then you have straight answers from them.
Good luck.
Dave in Muskegon
dg6772 is offline
post #7 of 8 Old 10-17-2013, 02:51 PM
CSP
There's a reason why it says 72-75 and not any other range of years. No it will not fit. Your axleshafts are a different spline count (19 as said already) and your differential sits right next to the passenger side leaf spring. On the 72-75 the diff is pretty much centered between the springs and uses a 30 spline axleshaft.
CSP is offline
post #8 of 8 Old 10-17-2013, 04:23 PM
chromegrille
1947 CJ2A
replace the bent hub and be done with it
assuming you have a tapered axle
chromegrille is offline
