1970 cj5 question - JeepForum.com
post #1 of 7 Old 04-15-2012, 06:54 PM Thread Starter
Jeeper48
1970 cj5 question
Im looking at buying a 70 cj5 and when i went to drive it today there was two shifters, one for the transmission and only one for the transfer case up by the fire wall. When i got home and started looking at different 70 cj5's there were two shifters for the transfer case. Is this normal or is something wrong with it?
Thank you
Mitchell
Jeeper48 is offline
post #2 of 7 Old 04-15-2012, 08:11 PM
NExOBLIVISCARIS
1970 CJ5
probably a warn overdrive like what i have
did it look like this
Jeepy (G-P) 1970 CJ-5 Renegade I, t86 with warn overdrive with a dana 18 , 4.88 rear end and a auburn pro series limited slip.
NExOBLIVISCARIS is offline
post #3 of 7 Old 04-15-2012, 08:13 PM
NExOBLIVISCARIS
1970 CJ5
its either a warn overdrive or a twin stick conversion for your transfer case
post #4 of 7 Old 04-15-2012, 08:25 PM Thread Starter
Jeeper48
yes it was missing the overdrive, is it ok not to have that and is it easy to locate one and put it in?
Jeeper48 is offline
post #5 of 7 Old 04-15-2012, 08:28 PM
chromegrille
1947 CJ2A
a factory 70 V6 would have only the single shifter for the transfer case.
a factory 70 4 cylinder would have two shift levers.
and of course by now, who knows what it could have.
and the OD could be used with both.
chromegrille is offline
post #6 of 7 Old 04-16-2012, 07:50 PM Thread Starter
Jeeper48
Will the dash out of a 73 cj-5 fit in a 70 cj-5?
Jeeper48 is offline
post #7 of 7 Old 04-17-2012, 09:37 PM
my-jeep-earl
1971 CJ5
The overdrive is an after market option and will probably cost you $700-$800, less if your lucky. I've gotten two off ebay, expensive! Also you'll need to know the spline count and teeth count of your transfer case to get the right overdrive.
Advanced Adapters bought the rights to Warn OD's and call them Saturn now, unless something's changed in the last year or so. Another is hermtheoverdriveguy.com.
my-jeep-earl is offline
1970 cj 5 mknherhappy Jeep CJ Forum 3 04-10-2012 04:16 PM
1970 dj5 RestoringDadsCJ Jeep CJ Forum 0 08-07-2011 10:15 PM
1970 Jeep CJ5 transmission question kooljp Jeep CJ Forum 7 04-18-2011 08:43 AM
1970 CJ-5 Newbie Question(s) scottsman Jeep CJ Forum 3 05-31-2010 01:37 PM
1970 CJ7 Question 1970jeepcj7 Jeep CJ Forum 1 10-28-2008 07:49 PM
