1970 CJ5 that has a chevy 400 small block - JeepForum.com
post #1 of 2 Old 01-06-2014, 06:47 PM Thread Starter
Rhambo
Hello-
I am looking at a 1970 CJ5 that has a Chevy 400 small block with a turbo 350 transmission. What are some of the advantages and disadvantages with having a motor this big? Are there any problems I should expect? Thanks for all the help!
Rhambo is offline
post #2 of 2 Old 01-06-2014, 06:56 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Extremely long drivetrain. This is usually compensated for by cutting the grill in order to push the engine forward. I would be checking the grill to insure it is mounted and secure. You will also want to check the rear driveline length. If it is running the stock offset D44 rear axle and 18 t case, you may be alright, as the 18 locates the driveline low in relation to the diff. If it has a 20, then driveline angles can become excessive, especially with a lift.
Insure the swap is clean. All mounts are solid, wiring is clean, steering is good, exhaust is done right, trans cooler is hooked up, and throttle linkages are safe.
You will have to be careful of the stock 27A front axle, as it won't stand up well to the SBC under load.
jeepdaddy2000 is offline
1970 , advice , chevy v8 swap , cj5
