Quantcast 1969 CJ5 project - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep CJ Forum > 1969 CJ5 project
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFG
Old 10-05-2009, 07:01 PM   #1
alex211
1969 CJ5 project
Well the journey has begun. I got the jeep for $900, I know stupid but live and learn. Better than the dirt bike it replaced. My plan is to fix all the rust. And then modernize it a little, like power saginaw steering, power brakes, and hydraulic clutch. The 225 is tired and smokes when you get on it and has a rod knock. Oh well, here are some pictures for you guys to enjoy.
2003 Rubicon
3" Zone lift, 1.25 body lift, 1" MML, 33" MTZs
alex211 is offline   Reply With Quote
Old 10-05-2009, 07:45 PM   #2
JrTjK
1982 J-Series Truck
best of luck with it!
if you haven't already, check out walcks4wd...semi-local to you and more than a great start to what you'll be needing.
Massachusetts members, pm me if you're looking for your Jeep parts locally at a great price & service.
JrTjK is offline   Reply With Quote
Old 10-05-2009, 08:19 PM   #3
alex211
Anyone know where to get the repair panels from the cowl around to the tailgate for both sides?
2003 Rubicon
Old 10-05-2009, 08:52 PM   #4
Pathkiller
1974 CJ5
Classic Enterprises should have what you need: Classic Enterprises - Restoration, Reproduction Parts for Studebaker, Jeep & Ford
Although it might be cheaper to replace the entire tub if you can find a decent used one from outside the rustbelt. I do see earlies show up on ebay often.
Pathkiller is offline   Reply With Quote
Old 10-05-2009, 09:08 PM   #5
JrTjK
1982 J-Series Truck
classic ent or jeep panels plus in maine are probably your best bet if you want made in usa parts.
Old 10-05-2009, 09:17 PM   #6
Jeepwine
1979 CJ5
I think the earth has done a good job of reclaiming that one
Don
Jeepwine is offline   Reply With Quote
Old 10-05-2009, 09:30 PM   #7
alex211
You guys just wait I'll get all the rust out someday. But in all seriousness this is a challenging build.
2003 Rubicon
Old 10-05-2009, 10:11 PM   #8
my-jeep-earl
1971 CJ5
No Guff, it will be! LOL
my-jeep-earl is offline   Reply With Quote
Old 10-05-2009, 10:48 PM   #9
SuB8HaVeN
Looks like a fun project. Good luck with it, and make sure to keep us updated!
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline   Reply With Quote
Old 10-06-2009, 07:06 AM   #10
alex211
Classic Enterprises didn't have a rear fender or rocker replacement panel, are Quadratecs repair panels any good? Does there rear fender panel come with the corner?
2003 Rubicon
Old 10-06-2009, 07:30 AM   #11
poppatello
I concur!!!
I say get a new body or a better rig...
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline   Reply With Quote
Old 10-06-2009, 08:37 PM   #12
alex211
Well I braced up the top rails and cut out some more bad metal. I just need to cut the rest out and build a tub from scratch. Should be fun.
2003 Rubicon
Old 10-06-2009, 08:46 PM   #13
Rick7
Keep in mind- At one time, that very Jeep you are working on, was brand new.
Rick7 is offline   Reply With Quote
Old 10-06-2009, 08:50 PM   #14
alex211
Hard to believe.
Can anyone measure the distance inside to inside edge of their tailgate opening? I have 36 1/4 inches and don't know if that for sure is right. I need to get some measurements so I know the body I make is square. Its funny until I actually realize all the work ahead of me.
2003 Rubicon
Old 10-07-2009, 03:25 AM   #15
keith460
Jeep. There's Only One
keith460's Avatar
You would be better off in the long run to get a new body as the time, effort and expense will far out weigh the cost of a new body. May the force be with you....good luck and hope you are making the right decision.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums/showthread.php?t=434226
keith460 is offline   Reply With Quote
Glock Forum
