1963 dana 44 torque specs...... - JeepForum.com
post #1 of 3 Old 07-08-2014, 02:35 PM Thread Starter
Unretarded
1963 CJ5
Lots of shims behind brake plate ....not sure how those work or what they set?
What do the shims do and is there a torque spec for the uts that hold the backer plate on?
Is the torque spec for the castle nut 250 ftlbs ?
Putting the brake bACKER AND Axle hub back on and just wantig to know how it all works in there and get it right.....thanks
Jeep...the first vehicle on the moon.....next trip we are bringing the tub!
It is gunna cost more and take longer than you thought...plan ahead!
Unretarded is offline
post #2 of 3 Old 07-08-2014, 04:42 PM
chromegrille
1947 CJ2A
backing plate to axle housing bolts 25-35 ft lbs
axle bearing end play .001-.006 which is what the shims you speak of are for
axle shaft end nut 150 ft lbs min
chromegrille is offline
post #3 of 3 Old 07-08-2014, 10:05 PM Thread Starter
Unretarded
1963 CJ5
Thanks, I appreciate the help...got it back together now and feel confident about it....we will see how it does on a test run......need to pull the passenger side part now and check it out as well.
Thanks once again, I appreciate it, just what I need to go forward !
