1959 cj5 - JeepForum.com
post #1 of 6 Old 09-12-2013, 08:43 PM Thread Starter
Vander55
1959 CJ5
1959 cj5
Hi new to the forum , first jeep for me but have had all sorts of hot rods ,4x4 trucks etc . This CJ 5 has a small block chevy conversion , with I think stock diffs and a Toyota trans/transfer. The body of course has issues and quite a bit of bondo from first glance. The motor had two spun rod brgs and a broken piston skirt, so pretty much a boat anchor .The wiring is a disaster as well as no brakes , a whole bunch of terrible construction by the previous owner/ builder?
My 10 year old believes it will be his and is working hard on it scraping parts . I have another motor and can fab most of the mounts etc that we will need.
My most pressing question at the moment is what you guys are using to convert the master cylinder to a dual reservoir type , can you do this and still use the stock pedal??Any ideas would help
Thanks
Ken
Vander55 is offline
post #2 of 6 Old 09-12-2013, 10:53 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Yes you can. You can use a 72-75 dual for drums MC. I believe hermtheoverdriveguy has a conversion bracket to get the MC under the floorplates. you will have to split the system front and rear (easy) and install a three way brass block in the front brake system to accommodate the light pressure switch.
jeepdaddy2000 is offline
post #3 of 6 Old 09-13-2013, 12:42 AM
willp07
1964 CJ5
As another early 5 owner, I recommend ditching the floor pedals for a swinging unit from 72 up cjs or xj work well. Ditch the stock heater then you can have power brakes and hydraulic clutch, and get a summit heater they work better anyways. Ive done the dual herm mc and advance adapters clutch linkage, works but having power brakes and a hydraulic clutch is much better.
willp07 is offline
post #4 of 6 Old 09-13-2013, 05:58 AM
hotrod351
1955 M-38
my setup is similar to yours. i installed a rebuilt mc 20 years ago and have never had any problems with stopping. the best thing you can do for these old jeep is power steering, not that hard to do.
hotrod351 is offline
post #5 of 6 Old 09-13-2013, 06:08 AM
colojeepguy
1970 CJ5
Another option for frame mounted dual master cyl.
http://shop.rp4wd.com/product/willys...conversion-kit
Some good info here-
http://www.earlycj5.net/forums/showt...cement-options
"It's better to have loved and lost, than to live with a psycho the rest of your life"
colojeepguy is offline
post #6 of 6 Old 09-13-2013, 10:19 PM Thread Starter
Vander55
1959 CJ5
Great info , thanks guys . Pressure washed the frame and transfer case etc today, off to work tomorrow
Ken
Vander55 is offline
