1957 cj5 info - JeepForum.com
post #1 of 7 Old 02-08-2004, 04:56 PM Thread Starter
jeepinarkansas
1982 CJ8
1957 cj5 info
Hello everyone, I am looking at buying a 1957 cj5, but just wanted to find a source if info on it. What axles came with them and transfer case, gearing and what not. It has the orginal Buick v6 motor and 3 spd tranny. Was this a good year? Thanks for any tips.
Jake
1982 Jeep Scrambler
5.3 Vortec
SOA on 37s
jeepinarkansas is offline
post #2 of 7 Old 02-08-2004, 07:37 PM
181jeep
Jake
If it's a '57 then there is nothing original about that v6, that wasn't offered until I think '64. It would have had an F-head 134. Rear axle should be a 44 and front a 25. Almost surely 5:38 ratio. Most likely a T90 tranny and for sure a d18 T-case. That v6 isn't a bad thing though unless the transplant was poorly done.
JB
1960 cj5 gm181 large port 4 cyl., sm465/model18t-case warn od, 5.38's d44 rear truetrac,model 27 front powerlock, bridgestone m/t 30x9.50x15
181jeep is offline
post #3 of 7 Old 02-08-2004, 09:11 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
19 spline(early) d44 in back, 27(a) in front. Originally had a t86 or t90 3 speed, but with the v6 transplant it's hard to tell with out looking. D18 transfercase.The nice thing about the v6(besides an increase in power), is it makes the power steering conversion much easier due to the availability of pump brackets. Check for split body seams in the rear as well as broken body mounts.
jeepdaddy2000 is offline
post #4 of 7 Old 02-08-2004, 09:37 PM
181jeep
Jeepdaddy,
No 27's in front until '61 and it would have early early 10 spline 44 axles in '57.
JB
181jeep is offline
post #5 of 7 Old 02-08-2004, 10:38 PM
jeepdaddy2000
1971 CJ5
Originally Posted by 181jeep
Jeepdaddy,
JB
25 from 45 to 53 with it running through till 64 in utility models. The 27 ran from 54 till 71 in Cj's and selected Waggy's. The 27 has 10 splines while the 44 had 19 on the tappered and 30 in the flanged, which I believe started in 70.
post #6 of 7 Old 02-08-2004, 10:57 PM
181jeep
Jeepdaddy,
I'm not gonna argue with you but your wrong. 19 spline in the 44 didn't start till early 60's and 27 were not put in cj's til 61.
JB
181jeep is offline
post #7 of 7 Old 02-09-2004, 09:59 AM
lynn
lynn's Avatar
Jake, for more info check out the forums at the link in my sig.
Lynn
'05 LJ
lynn is offline
Please Help with CJ-5 info KSIKON Jeep CJ Forum 6 01-03-2009 02:07 PM
CivilianJeep.Info Site Has It's First Info Page Up! JeepHammer Jeep CJ Forum 10 09-30-2008 02:28 PM
1957 cj5 brake swap? Luckyduck Jeep CJ Forum 3 08-19-2008 06:57 AM
1957 Willys CJ5 Jeepin_XJ_101 Jeep CJ Forum 1 06-04-2007 05:53 PM
1957 Cj 5 ROYALT91 Jeep CJ Forum 3 08-05-2005 03:56 PM
