1953 willys m38a1 transmission swap - JeepForum.com
post #1 of 3 Old 03-13-2013, 05:18 AM Thread Starter
g_shaw
1953 M-38
well im in a bit of a pickle on this one my transmission went out on my jeep and by no means am i a transmission person and i would like to upgrade from stock transmission to possibly a 4 speed. here is what i have i have a 1953 willys m38a1 with a 327 chevy in it and would like some recommendations on what transmission to use preferably a manual.
thanks
g_shaw is offline
post #2 of 3 Old 03-13-2013, 10:30 AM
duffer
1955 CJ3B
No brainer-SM 465. Bolts to the stock 327 bell and has the thinest adapter plate available giving you the longest rear driveshaft. An SM420 would also work but parts are getting a little tougher to find, there is more of a front driveshaft clearence problem, and the adapters are longer-it is somewhat lighter. Check Novak's site for the various options. You will have to modify both driveshafts, floor pan/transmission cover, and the cross member but lots of threads on that in several forums.
1955 CJ 3B, 381cid sbc (441cid all aluminum sbc coming soon), AGE M22W, Teralows, Warn OD, OBA, Premier Power welder, Warn 8274
1968 CJ 5, factory 225" w/ headers/450 cfm Holley, T86AA, Belleview winch, Warn OD
2012 Wrangler Rubicon Unlimited, Warn 9.5 xp-s winch
duffer is offline
post #3 of 3 Old 03-13-2013, 10:46 AM Thread Starter
g_shaw
1953 M-38
ok thanks for the info ill have to look into it
g_shaw is offline
