1951 Willys - What's It Worth? - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 1951 Willys - What's It Worth?
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 06-11-2011, 08:38 PM   #46
thomask
AFTER (Nice work there Outlaw1)
Wife: "This thing rides like a JEEP"
Husband: "Yes dear!"
"Hey wave at a classic JEEP owner and make a new JEEP friend"
thomask is offline   Reply With Quote Quick reply to this message
Unread 06-11-2011, 09:21 PM   #47
CALOcruiser
CALOcruiser's Avatar
1978 CJ7
Very nice Outlaw! Can't wait to see how the motor turns out.
Really adding to my itch to ask the old man down the road what's up with the Willys sitting in his driveway that I've never seen move.
The '78 CJ7 may need a little brother.
CALOcruiser is offline   Reply With Quote Quick reply to this message
Unread 06-15-2011, 02:08 PM   #48
Outlaw1
Unfortunately yesterday I returned to work only to be terminated. Bummer.
Before I leave Colorado and head back to Texas I thought I'd tinker with the Willys. I had planned on ordering a new starter and converting everything to 12V. Since I don't want to spend any money I just tore the original starter apart, cleaned everything and put it back together. The distributor didn't look like it was timed right, so I pulled it, cleaned it and set it where I thought it would be close. After I put the plugs back in and hit it with a shot of starting fluid the engine turned over and fired right up! The carburetor still needs to be rebuilt or I need to buy a 2bbl/1bbl adapter for the Weber, but now I know the engine runs!
Outlaw1 is offline   Reply With Quote Quick reply to this message
Unread 06-15-2011, 02:29 PM   #49
CALOcruiser
1978 CJ7
Man, that sucks! But the bright side may be that you have more time to work on the Willys!
the drawback is, no money to buy parts.
Sounds like you have a good plan. Congrats on getting the motor running! Would be kinda cool to restore the original carb if you can. Likely cheaper too.
Unread 06-15-2011, 07:12 PM   #50
Outlaw1
I'd prefer to have the old carb on the engine, but more than likely the throttle shaft bushing is worn. Next week I'll be back in Colorado to start gathering the rest of my things and bring the Willys and my dually back to Texas. When I get the Willys home I'll be able to get it on the lift and go through it a little better. Unfortunately, with the 100+ temps back home I doubt I'll be driving it much until it cools off.
Unread 09-23-2011, 01:22 AM   #51
Thexonexkid
Thexonexkid's Avatar
1986 XJ Cherokee
is there a build thread for this, i am sub to this but is there another one?
84 CJ7 Rebuild:
http://www.jeepforum.com/forum/f8/cj7-re-build-1299733/
Thexonexkid is offline   Reply With Quote Quick reply to this message
Unread 09-23-2011, 09:30 AM   #52
mike76CJ5
1976 CJ5
yea - i'm interested as well...
mike76CJ5 is offline   Reply With Quote Quick reply to this message
Unread 01-03-2012, 12:19 AM   #53
Outlaw1
Unfortunately, I haven't started a build thread because it's such a pain to do from my phone.
It really didn't take much to get the Willys on the road. I cleaned out the tank, rebuilt the carb, removed the electric fuel pump, connected the stock fuel pump, replaced a freeze plug, bled the brakes and aired up the tires before I took it for a ride. The generator needed a set of brushes and viola, it works! After replacing the steering stabilizer it even drives pretty good. At some point I'd like to have some stock seats, but for the meantime the seats have been replaced with some old plastic Jaz Baja Busters.
I'm not sure I mentioned it before, but it does have the original L-134, T90, D18 and D-27/D-44 w/5.38's. The only thing a little disappointing is the lack of power. Top speed uphill is ~45mph, downhill is ~55mph. I'd like to do a consistent 60mph. Even though I hate to see it go, I'm seriously considering a 4.3/T-18/D20 (with 18 internals) swap. For the time being I'm just enjoying it.
Unread 01-03-2012, 01:28 AM   #54
Cutlass327
Cutlass327's Avatar
1978 CJ5
Just take the OE drive line out, set it off to the side, and do the swap you want. Do it all bolt-in, with no major hacking if possible, so that it can go back to original if you ever decide to.
Just a note, I have read where many have said not to trust the steering design on some of those old Willy's. that they have a lot of play and unstable at higher speeds..
Rick
http://www.jeepforum.com/forum/f8/ri...8-cj5-1223197/
Cutlass327 is online now   Reply With Quote Quick reply to this message
Unread 07-27-2013, 09:43 PM   #55
SKT
1981 CJ7
Bump for updates...
Click here to see thousands of 'Abandoned and Neglected' Jeeps rotting away...
SKT is online now   Reply With Quote Quick reply to this message
Unread 07-28-2013, 08:33 AM   #56
hotrod351
1955 M-38
offer him the least amount you can. you might think he has a gold mine.then sit back and wait. from what you said people arent beating his door down to buy it. id tell him $500.00 and thats it. if he said it runs then id say = give me a call when you get it running, i sure wouldnt try to get it started myself, if you did then he could raise the price, after all it would be running then. it also seems that it didnt cost him anything. hope it works out for you.
hotrod351 is offline   Reply With Quote Quick reply to this message
Unread 06-05-2014, 08:42 PM   #57
Outlaw1
Unread 06-06-2014, 08:13 AM   #58
hotrod351
1955 M-38
agree, not much. if you cant drive it to hear what noises its going to make and if it smokes, knocks rattles. well then maybe $400.00 or $500.00. maybe not even that.
Unread 06-06-2014, 08:48 AM   #59
duffer
1955 CJ3B
OK guys, this thread started 3 years back, the Willys was purchased and presumably moved from CO to TX.
Hopefully, outlaw will give us an update on this sometime soon.
1955 CJ 3B, 381cid sbc (441cid all aluminum sbc coming soon), AGE M22W, Teralows, Warn OD, OBA, Premier Power welder, Warn 8274
1968 CJ 5, factory 225" w/ headers/450 cfm Holley, T86AA, Belleview winch, Warn OD
2012 Wrangler Rubicon Unlimited, Warn 9.5 xp-s winch
duffer is offline   Reply With Quote Quick reply to this message
