1951 Willys - What's It Worth? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 1951 Willys - What's It Worth?
Unread 06-03-2011, 09:31 PM   #16
thomask
SUPER, we are waiting an update on engine and any major rust areas.
Are you planning a a resto or mod?
Will reply for more pics...
Wife: "This thing rides like a JEEP"
Husband: "Yes dear!"
"Hey wave at a classic JEEP owner and make a new JEEP friend"
thomask is offline   Reply With Quote Quick reply to this message
Unread 06-03-2011, 09:46 PM   #17
Skerr
Dang those things are cool looking! Way to go.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 06-03-2011, 11:22 PM   #18
Outlaw1
Just got home a little while ago. It's too late to mess with it tonight. Tomorrow after work I'll swing by and pull the Willys over to the house. If I can get the tires to hold air I'll clean it out then try to pull it down to the car wash. After I rinse it off and see what's under the grime we can go from there.
Outlaw1 is offline   Reply With Quote Quick reply to this message
Unread 06-03-2011, 11:23 PM   #19
jeepinvader
Congrats on the find! More pics please.
Free Chuck!
jeepinvader is offline   Reply With Quote Quick reply to this message
Unread 06-03-2011, 11:44 PM   #20
Outlaw1
More to come tomorrow!
Unread 06-06-2011, 01:50 PM   #21
Outlaw1
Digging into a new project is always exciting. So far I haven't gotten the engine running, but it does show some promise.
The bad part is the starter is dead. It won't even budge. I tore it down and it's pretty well trashed. This is a good opportunity to get rid of the 6 volt system and upgrade everything over to 12 volt unless I can find another starter somewhere close. More than likely I'm going to try one of the Nippondenso gear reduction starters I see online. From what I can see the ring gear on the flywheel needs to be changed out too. Hopefully it will at least live while I'm trying to get the engine to run. I'd like to get the engine started, then later on pull the transmission/t-case to rebuild them when I do the ring gear. I have a fully equipped shop, including a 2-post lift back home. It's very nice having a lift, transmission jack, etc.
The good part is the body doesn't have very much rust at all, but it does have tons of little dings and dents. When I pulled out the 500lbs of vintage 1972 carpet and jute I fully expected to see major holes in the floorboards. There's one hole ~3" in diameter in the passenger floorboard, but the rest looks pretty good other than dents. I'll straighten them up the best I can, then throw some POR15 on them. The exterior has a couple of rust holes that are 1/2"-1" and tons of small dings and dents. At one time the windshield frame was smacked really hard on the driver side and someone hacked it up trying to straighten it out. As far as the hood goes, it has some dents and some other issues, but it's salvagable. Amazingly, the frame is absolutely perfect. Even the tires are holding air fine. Saturday I towed it to the car wash and dumped $20 into getting it clean inside and out.
Another good thing, the engine spins over, so it's not locked up. I tested the ignition system and it's working and looks pretty new. Of course the carb is full of varnish and probably wasn't very good anyway by the looks of the carbon fouled plugs.
The initial parts list is looking like this. Starter, alternator, fuel pump, misc. 12 volt conversion parts & misc. tune-up parts. There is a fuel pump/vacuum pump on the engine, but it's bypassed and there's an external electric fuel pump that looks new (and doesn't work). I'll just replace it with a regular engine mounted pump. The bushings in the Carter W-O look to be a little worn and I can't find any high altitude kits. I happen to have an older Weber, so I'm planning on bringing it back to Colorado this week when I go home and ditching the W-O.
I have to admit, it looks much better without the shreded top and the hacked rollbar. When the towbar is gone and I attack it with some rattle cans it will look like a totally different vehicle.
Unread 06-06-2011, 03:41 PM   #22
thomask
outlaw1
You are tempting us, how about some post car wash pictures?
Unread 06-06-2011, 03:42 PM   #23
thomask
outlaw1
Thank you!
Unread 06-06-2011, 03:48 PM   #24
mastercraftka
mastercraftka's Avatar
Originally Posted by Outlaw1 View Post
We agreed on a price. This evening I'm going to meet the owner halfway and exchange some cash for the title. Hopefully I'll be back early enough to get it moved over to my place and tinker with it a little before it gets too late. Tomorrow is a short work day for me, so regardless I'll get something accomplished before the weekend is over.
How much did you pay?
mastercraftka is offline   Reply With Quote Quick reply to this message
Unread 06-06-2011, 04:15 PM   #25
mopar408
1974 CJ5
If you decide to keep the old Military tires on it, I know where there are a bunch of good ones cheap.
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline   Reply With Quote Quick reply to this message
Unread 06-06-2011, 04:20 PM   #26
Thexonexkid
Thexonexkid's Avatar
1986 XJ Cherokee
O man, I am super excited to see this...
If this could be moved to the build forum now???? Or at least when you do start a build thread post link in here...or if this will be the build thread and its staying here thats fine cause im already subscribed...
Need Need more
Great find Outlaw
84 CJ7 Rebuild:
http://www.jeepforum.com/forum/f8/cj7-re-build-1299733/
Thexonexkid is offline   Reply With Quote Quick reply to this message
Unread 06-06-2011, 04:21 PM   #27
DANSBIRD
My granddad has one... it needs a new body on it b/c his is about rusted out. That thing will go damn near anywhere. Awesome little ride, but a PITA to drive, compared to my TJ.
DANSBIRD is offline   Reply With Quote Quick reply to this message
Unread 06-06-2011, 04:27 PM   #28
austinaubinoe
If it were mine id let the body be. Its has a GREAT patina. Curious to know how much you paid, anything under 2k would be a deal IMHO.
austinaubinoe is offline   Reply With Quote Quick reply to this message
Unread 06-06-2011, 08:46 PM   #29
thomask
JUST SUPER, you sure that is not a MAC with that Big Dog hood ornament.
What a great classic.
Unread 06-07-2011, 02:37 PM   #30
SKT
1981 CJ7
...I attack it with some rattle cans it will look like a totally different vehicle.
I would not spray it. That is a great example of patina, and you would be suprised how much it would "pop" if you hit it with CLR. This teqnique seems more popular with old air cooled VW's, but I think it would look great on an old Willys. They even clear coat over the body once it has been hit w/ the CLR.
It has GREAT patina.
Agreed, agreed, and also curious!
Click here to see thousands of 'Abandoned and Neglected' Jeeps rotting away...
SKT is offline   Reply With Quote Quick reply to this message
