03-03-2010, 08:58 PM
#466
I have began work on my doors. I took a different set off my pile, instead of using the other ones I have already worked on simply because these are straighter.
03-05-2010, 06:12 PM
#467
Originally Posted by Lifesgoodhere
Still waiting for my doors to thaw out from under the snow....
Wha, Wha, WHAT???
Your doors were outside under the snow. . .
Glad to see you reclaimed them though.
'94 Jeep YJ Wrangler
4.0L I-6/AX-15 5-spd./NP231 2" Body Lift
'49 Jeep Willy's Truck
350SBC/TH350/NP205, 14-bolt rear/D60 front
40" BFG MTR's on H2 8-lugs
03-05-2010, 09:36 PM
#468
haha yep. still got snow on the ground from the first big storm back on like December 19th or so. Finally melting!
03-05-2010, 09:39 PM
#469
OH yeah anyone want a running f-head engine? $150 a pop (I got 3, see back round of last pic) plus freight shipping, or you p/u also the 161ci 6 cyl needs to go....$8.50/hundred at the scrap yard it looking better and better for them every day!
03-05-2010, 10:11 PM
#470
Hope you decide not to scrap them. . .I know not everyone is looking for them (I'm certainly not. . .) but it's a shame to see vintage iron getting scrapped. . .
. . .I'm right there with you though. . .I've got the original Timken 1-ton rear axle and the original D25 front axle that I can't seem to get rid of. . .and the scrap heap is tempting, but I'm gonna hold onto them for someone who needs them for restoration. . .I'd practically give them away to someone who could pick them up and was going to use them for a restoration.
03-06-2010, 04:30 AM
#471
I re timed the ignition timing. I was sitting around 10* ATDC. Stock is 5* BTDC. I stuck it at ~0* TDC runs way better now. Re torqued the head after running it through a few heat cycles. No leaks.
What made you want to initially retard the timing 15 degrees from stock? I know you raised your compression .8:1, but that would explain the big loss in power... Glad things are running good again. If it were me, I'd run it on the stock setting and see how it acted. But, then again, if it's fine, no sense in messing with it (although that's NEVER, EVER been my motto  ).
03-06-2010, 05:21 AM
#472
? you aren't making sense. Retarding the timing makes the spark go off sooner, this is for lower compression engines. less compression, more PISTON TRAVEL in the cylinder BDC timing is so that the fuel is properly burned when it starts going off rather than only partly, also begins with the valves....... (it gets super techie after that)
Raised compression gave me more torque I can feel it (let of clutch high 2wd, no gas.) I made the timing 0*TDC to compensate for the stock setting (5*BTDC) all in all its on the stock setting. Advancing the timing makes the spark go off on the down stroke. Higher compression needs this to prevent pinging (fuel igniting because of compression and not the spark.)
03-06-2010, 05:40 AM
#473
I perfectly understand the mechanics of piston travel and ignition timing...I've built several high-performance race engines for myself, and others as well...
Low compression/high compression, ignition timing does the same thing -- ignites the fuel. You went from having 5 degrees BEFORE TDC to 10 degrees AFTER TDC...retarding your timing 15 degrees. Then complained about a loss in power. Yes, raising compression increases torque, that is a well known fact. Retarding your timing any amount, especially by 15 degrees, will drop power by a lot. I was just curious where you got that amount from.
EDIT: ADVANCING the timing makes the spark go off sooner...you might want to check that fact.  Advance = earlier
03-07-2010, 12:07 AM
#474
opps. my mistake. it was early in the morning I wasn't quite awake yet...got my facts backward (ignition timing advance/retard). Good call, kudos to you.
05-09-2010, 09:40 AM
#475
Hey, anything happening recently? What do you need to do to the doors? I'd be interested to see what you're doing with them...I've got a bit of a mess in mine (window regulator thingy falling off, kinda bent up, some other parts missing...)
Any updates on getting the truck painted?
1949 Willys jeep truck. 2wd, 2.8l, T90E-1, Timken. Under construction.
1953 Willys jeep truck. 4wd, 2.2l, T90A/Spicer 18, Timken/Dana 25. Parts...or Cummins 4bt...?
1956 Willys jeep truck. 4wd, no drivetrain. Big back window.
06-09-2010, 07:54 PM
#476
Hey still here everyone.
Last 3 months I have been scrapping junk I will never use/couldn't sell or give away (no one wanted it) ~10,000#s of scrap iron, @ ~$7.50/hundred lbs. made back some lost expenses from getting the stuff to begin with.\
Rebuilt another engine. 2 lift kits, a timing belt repair, and a few dozen brake jobs in the afternoons in my shop after work; turning in 50 hour consistent weeks; and a steady girlfriend im with several evenings and days a week with.....I think I can finally financially get back around to the this project again.
cleaning my tools and shop, then working on the doors. hopefully be done with them by the 4th of July so I can put it in the local parade.
Cheers
06-23-2010, 05:59 PM
#477
Good to hear!!!
06-23-2010, 11:24 PM
#478
Glad to hear that things are looking up for you Jake! Keep us posted (You know we love pics!)!
Be well,
Richard
'87 YJ Laredo My Daily Driver
'02 TJ X Fiancee's DD, and our Trail Rig
'65 M-416 Trailer
Live each day as if it were your last, 'cause you just never know.....
06-29-2010, 11:10 PM
#479
yea thanks richard, the doors i will have to rebuilt the entire bottom cowl. It has rotted out, and or metals too thin for my liking....welding with it is annoying. got 1/2 of one door finished with the patch repairs, about 5 hours with a grinder, a sharpie, and the ol Hobart.
Metal surgery...cut, cut some more, patch panels, and weld em in, tedious, but I do it well.
Moving into an apartment in about 3 weeks, so things will slow down even more after that happens, work on it when I can. Funny thing is I got every thing I need to finish it, but short on time.
Pictures Friday. I promise.
07-06-2010, 10:08 PM
#480
