151 CID GM Valve Cover Gasket ? - JeepForum.com
post #1 of 3 Old 06-24-2013, 06:55 AM Thread Starter
Conch Cruiser
1983 CJ7
I just pulled my valve cover. It appears Jeep does not use a gasket during manufacturing. It appears they used an orange RTV sealant only. I already picked up a new gasket. Should I put it back the way it was with just RTV, or use the gasket plus RTV.
Thanks,
Conch Cruiser
1983 CJ7-Base
151 GM Motor
5 speed
Conch Cruiser is offline
post #2 of 3 Old 06-24-2013, 11:38 AM
jumbojeepman
1976 CJ7
Really, you don't think the valve cover has been off the engine once in 30 years? My guess is a previous owner did the RTV hack job.
jumbojeepman is offline
post #3 of 3 Old 06-24-2013, 07:47 PM Thread Starter
Conch Cruiser
1983 CJ7
“Really, you don't think the valve cover has been off the engine once in 30 years? My guess is a previous owner did the RTV hack job.”
Really.
I purchased thee jeep from the original owner who is a friend of mine. He does not recall ever pulling the valve cover.
I reviewed the Haynes Manual prior to removing the valve cover. It instructs you to re-install the valve cover with a bead of RTV only.
My question was. “Should I put it back the way it was with just RTV, or use the gasket plus RTV”
I assume from your response, you would use a gasket.
Any other suggestions?
