15.5 inch wide tires on a CJ-5? - Page 2 - JeepForum.com
post #16 of 17 Old 12-12-2002, 12:18 PM
cj5goliath
cj5goliath's Avatar
1980 CJ5
I've had the u-joints break just turning corners at low speeds with large tires. Maybe the earlier cj's were a little heavier duty....i'm not sure.
Don't play leapfrog with a unicorn!!!
http://www.cranked-up.com
cj5goliath is offline
post #17 of 17 Old 12-15-2002, 10:41 PM
91XJLimited
91XJLimited's Avatar
I'm not on ANY side here, I'm just bored, and looking for someone to help. If it were me, I would DEFINETLY get the offset rims, not the spacers. They make offset rims for a reason. The center of the wheel, is the center, no matter what the backspacing is. The backspacing, is the distance from the outside of the rim, to where it is secured by lugnuts to the axle. The center is the center. If anything, spacers would be the thing that puts stress on the wheel. I don't really understand how a wheel could put stress on itself, but whatever. If you go with a spacer set-up, I hope you have a thick wallet. Just think of all the things you could buy instead of putting in new axle shafts, lugs, and then finally realizing you need more backspacing on your wheels, and buying a new set of wheels.
91 XJ Limited - RE 5.5" XD, 32x9.50 TSL's, 4.0 HO, disconnects, other good stuff
94 ZJ 5.2 Limited - 6.5" Teraflex lift, Clayton Long Arms, disconnects, 37x12.50 SSR's, Hummer Beadlocks, and more good stuff
91XJLimited is offline
Anyone running 15.5 wide tires on a CJ ?? only in a jeep cj Jeep CJ Forum 1 06-23-2009 05:30 PM
4 inch Rough Country Lift on 28 inch tires CrazyFlippinCJ7 Jeep CJ Forum 16 03-02-2008 02:09 PM
13.5" Wide Tires Under A CJ? burtonsnowman Jeep CJ Forum 11 05-15-2006 12:16 PM
Wide tires vs. Thinner tires Jeepbeeper Jeep CJ Forum 11 09-08-2004 04:39 AM
Does anyone have any pics of a jeep with a 6 inch or more lift and 35+ inch tires? jeepcj7 Jeep CJ Forum 10 03-23-2003 08:39 AM
