14 bolt GM Rear Differential - JeepForum.com
post #1 of 13 Old 02-10-2010, 12:38 AM Thread Starter
kluman
1979 CJ5
I want to put GM 14 bolt differentials under my 1979 CJ 5. It has a 304. Is that big enough for those heavy differentals?
kluman is offline
post #2 of 13 Old 02-10-2010, 03:59 AM
CJ_heath
Gear ratio? TIre size? What kind of wheeling do you do?
The 14 bolt hangs low, because the diff is huge, so if you aren't putting at least 37-38 inch tires I don't think it would be worth it, because it would be an overkill.
CJ_heath is offline
post #3 of 13 Old 02-10-2010, 04:27 AM
kercher
kercher's Avatar
it is also quite wide, usually 69" wms-wms i think depending on srw/drw. How are the tire coverage laws?
kercher is offline
post #4 of 13 Old 02-10-2010, 04:38 AM
CJ_heath
If you run C&C hubs you can get the WMS~WMS measurement down to around 63". Just throwing that out there.
ALSO: kercher I clicked on your jeep link in you signature and it appears to be broken. I wanted to check it out.
CJ_heath is offline
post #5 of 13 Old 02-10-2010, 08:18 AM
CSP
The SRW 14 bolt is 67.5" wms to wms. The cab & chassis is 63.5". The dually pickup version is about 72".
Unless you're on 38" or taller tires you don't want a 14 bolt unless you intend to drag the rear axle over everything.
There is no such thing as a 14 bolt front axle in reference to "differentials" from the OP (unless you build your own).
CSP is offline
post #6 of 13 Old 02-10-2010, 09:39 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
There is. AAM started building and testing their 1050 front last year (direct email response after I inquired about one for my Dodge).
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #7 of 13 Old 02-10-2010, 02:14 PM
kercher
kercher's Avatar
good point about the hubs, and thanks for the note. should be fixed now.
kercher is offline
post #8 of 13 Old 02-10-2010, 02:23 PM
CSP
True, but that really isn't the "14 bolt" that's being referred to here, at least as I read it.
CSP is offline
post #9 of 13 Old 02-10-2010, 02:31 PM
PavementPounder
Cool as Ice...
Are you saying as a matter of semantics that an AAM 1050 isn't a 14bFF?
Because if you are, I respond with AMC15/Dana 35.
post #10 of 13 Old 02-10-2010, 03:27 PM
CSP
No, I'm saying that the widely used term is generally in reference to the GM 14b FF, especially in reference to swapping them under Jeeps. As in the predecessor to the AAM 1050, prior to AAM as a spin off from GM. Different company, different axle.
We don't call a Dana 44 a 10 bolt, despite them having 10 bolts holding the cover on.
Edit: The OP specifically said "GM 14 bolt differentials". GM didn't make a 14 bolt front axle.
CSP is offline
post #11 of 13 Old 02-10-2010, 03:51 PM
PavementPounder
Cool as Ice...
By that logic, HP and LP D44's should not be the "same axle" due to differences in the housing parts. Differential models are defined by the ring & pinion relationship. The AAM is the 14bFF with some updates.
No, we don't because it is not the same ring & pinion design as the GM 10b - regardless of what other parts are bolted to the housing that might be shared with other model axles.
post #12 of 13 Old 02-10-2010, 04:06 PM
CSP
I think we both know that the OP wasn't talking about the AAM axles, which is my point. I'm going to leave it at that rather than arguing jsut for the sake of arguing.
CSP is offline
post #13 of 13 Old 02-11-2010, 06:24 AM
No_Bs
1977 CJ5
The 14 bolt is an Eaton with updates, but we don't call it a 14 bolt.
1977 Cj5, 258, T-18, 2.46:1 Dana 20, 2.5" BDS lift, OBA, 38.5's. Chevy 60 frt, 14b Rear, Full hydro, 102"wb, full DOM cage.
No_Bs is offline
AMC 20 Rear Differential question luvdemCJ's Jeep CJ Forum 18 08-19-2011 07:22 PM
rear differential oil ceejaysvn Jeep CJ Forum 12 03-28-2009 12:27 PM
Hot rear differential. jlutsey Jeep CJ Forum 4 06-08-2007 09:41 PM
rear differential rubbing CJ7Dex Jeep CJ Forum 1 01-03-2006 10:47 AM
Rear Yoke strap and bolt VS. U-Bolt???? HELP PLEASE! scottahicks Jeep CJ Forum 6 06-11-2004 11:30 PM
