134 F engine starting problem - JeepForum.com
post #1 of 4 Old 05-24-2004, 09:47 AM Thread Starter
wijeeper18
I have been working on trying to get the 134 engine to run in my jeep. I have tried 2 different carburators, replaced the components in the distributer and the distributer shaft itself with a used one from a running 134 and believe that i have them set correctly and i have new plugs that are getting spark. I have tried adjusting the timing and i cant get it to run. The best that i get is an occasional backfire. The old distributer required upward pressure on the shaft itself in order for it to run. I am at a loss to what the problem is. Any suggestions would be appreciated.
wijeeper18 is offline
post #2 of 4 Old 05-24-2004, 10:38 AM
71CJ5
71CJ5's Avatar
Try posting over on www.earlycj5.com/Forum
We have lots of F-head gurus over there.
1971 CJ5: 225, HEI, Headers, T-14, D18, Warn OD, 30/44, Saginaw steering, 33's
http://community.webshots.com/user/71cj5
71CJ5 is offline
post #3 of 4 Old 05-25-2004, 12:33 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Check in this order
1 firing order...ensure that the it is set up in relation to the direction of rotation and you don't have it 180 degrees off(#1 firing on the exhaust instead of compression stroke).
2 Insure it is getting fuel. visualy check to see if the acccelerator pump is squirting fuel.
3 Compression. If the engine has been siting for a long time, the exhaust valves can become sticky,causing compression to become erratic.
Other things to look for...sheared distributor(oil pump)gear roll pin,broken timing gears,stuck rings.
jeepdaddy2000 is offline
post #4 of 4 Old 05-25-2004, 09:26 PM Thread Starter
wijeeper18
thanks for the replies, i got it figured out. plug wires were off by one.
starting problem, please help hillbilly68 Jeep CJ Forum 20 11-25-2006 10:32 AM
85 CJ Starting Problem bmg97 Jeep CJ Forum 5 05-09-2006 04:46 PM
Starting problem Burrlap Jeep CJ Forum 6 08-30-2004 08:29 PM
Starting problem nsamaster0414 Jeep CJ Forum 11 08-23-2004 02:03 AM
Problem Starting "warm" Engine MudLover Jeep CJ Forum 2 06-08-2003 11:57 PM
