1227747 ecm differences - JeepForum.com
post #1 of 6 Old 03-12-2010, 11:16 PM Thread Starter
CJ7Rubicon
CJ7Rubicon's Avatar
Is there a difference between a ecm from a 4.3 v6 and one from a 350 v8?Some pins are broken in the one I have where the wire connects,so i need to go to the jy and get another.This is going on a 258.I have searched,but did not find an exact answer.
85 CJ7,Clifford equipped 258,TBI,RE4.5,35" Claws,Aussie lockers,8.8 rear.
Blue Jeep Club Member #134
CJ7Rubicon is offline
post #2 of 6 Old 03-13-2010, 04:11 AM
gmakra
The ECM is the same the chips are different. So pull your old chips and replace them into your new ECM.
gmakra is offline
post #3 of 6 Old 03-13-2010, 04:50 AM
Mike Romain
??????? ECM?
On your 258, the ECM has gone into limp home mode and is no longer functioning because you do not have a feedback carburetor on there. It can be bypassed easily and even be tossed in the trash to make the timing work properly.
The 258 is a straight six 4.2L engine that does not share much with a 4.3 V6 or a 350 other than the name 'engine' so I really don't understand the cross reference question.
Mike
Mike Romain is offline
post #4 of 6 Old 03-13-2010, 07:52 AM Thread Starter
CJ7Rubicon
CJ7Rubicon's Avatar
Mike,sorry for the confusion.I am doing the jy tbi,getting rid of my carb.
post #5 of 6 Old 03-13-2010, 10:04 AM
jfwireless
1976 CJ7
gmakra is correct, the 1227747 ECM's are all the same, just the images on the prom are different for the different programming required for different engines.. You can read the broadcast code label on top of the prom, here are just some examples, this is usually on the outside of the ECM case as well:
  • ABUL 1987 Astro with the 4.3 Z TBI,1227747
  • ACSU0024 1987 V 1500 (Suburban) 5.7L, 700R4, 4x4, 3.73 axle ratio, and AC.
  • ACSW 87 C1500 pickup, 5.7L TBI w/T700R4,1227747
  • AFDY6022 5.0 automatic
  • AJUK 88 C1500 pickup, 5.0L, Auto, 1227747
  • AKAJ1147 1987 K 1500 5.7L, 700R4, 4x4, 3.73 axle ratio, leaded compatible (no closed loop) and AC.
  • AKAL 87 5.7L automatic
  • AKAR1180 5.7L manual leaded fuel option (no closed loop)
  • AKDX2088 4.3L automatic
  • AKSN 88 4.3L 5spd
  • AMUR 88 C/K pickup, TBI EFI system, 1227747
  • ANLW5469 89 5.7L automatic
  • ANLZ5483 5.7L automatic
  • ANTZ 89 7.4L manual
  • APAB 4.3L manual 3.42 rear end ratio
  • ARHT7465 5.7L manual
  • ARPC7509 5.0L manual
  • ASDU 1991 Chevy C-1500 5.7L V8 Auto
  • ASDW9544 5.7L manual
  • ASDZ9578 5.7L automatic
  • AZFT9503 7.4L automatic (THM400)
Jim
jfwireless is offline
post #6 of 6 Old 03-13-2010, 11:29 AM Thread Starter
CJ7Rubicon
CJ7Rubicon's Avatar
Thanks wireless,I did find that off of the binder site.My broken one is the ABUL.
I have a chip flashed for my engine due to the cam,header and bore.Im glad i can get any 747 and use my flashed chip and the original longer chip in the other slot.I just wasnt 100% sure.
1227747 , ecm , efi , jy tbi
junkyard efi, tuning 1227747 .bin files mike06X Jeep CJ Forum 11 03-30-2010 09:24 AM
Tub differences mxracer513 Jeep CJ Forum 3 11-15-2009 08:59 PM
help with dj5 and cj5 differences!!?? jeepdj5fan Jeep CJ Forum 1 01-07-2009 07:59 PM
D30 differences!?! VACJ5 Jeep CJ Forum 3 10-10-2008 04:45 PM
Differences between 75 and 76 cj5 jeepboy90 Jeep CJ Forum 3 01-02-2006 12:23 PM
