1 step forward, 2 steps back - JeepForum.com
 1Likes
  • 1 Post By Cutlass327
post #1 of 7 Old 05-20-2016, 06:59 AM Thread Starter
frank74cj5
Cj 1 step forward, 2 steps back
rebuilt my 258 b/c of a cracked piston. finished install this week and motor runs like a top! HOORAY! Problem is, cj7 won't engage tranny. Is it possible that i missed when i mated the engine and tranny? it bolted together cleanly and did not seem to be in a bind. is it possible that the transfer case is in nuetral? Sure would be nice to get back rolling. Any help or suggestions are greatly appreciated.
frank74cj5 is offline
post #2 of 7 Old 05-20-2016, 07:01 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Not possible but did you remember to install the clutch?
Yes, it could be the t-case could be in neutral..
John Strenk is offline
post #3 of 7 Old 05-20-2016, 09:28 PM Thread Starter
frank74cj5
ur probly right, sort of. i did install clutch, but i believe it is installed backwards. On the center slined hole, the long side should face tranny, short side face engine. i'll bet it's flipped backwards. have to repull engine and check. sigh. no other explanation.
post #4 of 7 Old 05-20-2016, 09:36 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I'd check the transfer case shifter first! Also verify clutch linkage is proper and not holding clutch released. Could also be the clutch fork not installed properly so it is pushing the throw-out bearing in holding things released...
TIPPEDITOVER likes this.
Rick
Cutlass327 is offline
post #5 of 7 Old 05-21-2016, 11:02 AM
TIPPEDITOVER
In the Lab
TIPPEDITOVER's Avatar
1978 CJ5
IF this is what happened, I've been there and done that brother, feel your pain. It's not a mistake you make twice in your life.
"Societies that lose the cohesion needed for concerted, collective action collapse, either by failing to meet an external threat or from internal conflicts."
Shaun
1978 CJ5 - Rebuild in progress......
TIPPEDITOVER is online now
post #6 of 7 Old 05-21-2016, 04:03 PM
John Strenk
1976 CJ5
Well I would think that if the clutch was installed backwards, then it would not dis-engage.
post #7 of 7 Old 05-26-2016, 03:07 PM Thread Starter
frank74cj5
Well, good news first. The clutch was indeed flipped around. Can't believe i did that. Problem resolved. New prob to chase down? Hot tranny and leaking tranny fluid somewhere. Love catching up on 30+ years of neglected yet required and recommended maintenance. Wish I had bought this jeep new 32 years ago instead of used a few years ago. It would probly be a lot better maintained. But I've wanted one for as long as I can remember, so............ONWARD AND UPWARD!!!
