1 piece or 2 ? (AMC 20) - JeepForum.com
post #1 of 9 Old 05-20-2015, 10:04 PM Thread Starter
herb812
1983 CJ7
Since axle seal is leaking. I've been told to change from 2 to 1 piece axle's (running a stock 304). Are the 1 piece that much stronger ? Also, where can I find ring/ pinion backlash specs and manual.
herb812 is offline
post #2 of 9 Old 05-20-2015, 11:23 PM
holliewood61
1981 CJ7
Yes they are that much stronger. Backlash is 0.006"-0.010". You can find a fsm on ebay or there are downloadable versions online
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline
post #3 of 9 Old 05-21-2015, 02:17 AM
BagusJeep
1981 CJ7
They are stronger but as with all things Jeep, you should question whether it is "necessary" or just received wisdom and whether your epensive hobby could use that money on something else.
2 piece axle shafts can happily last 30 years behind a 304. The problem comes when for some reason the torque on the Axle Nut starts to slacken and the parts start to move and fret, sudden failure often resulting. This can be brought on by big tyres (37" plus) which put a a lot of leverage on the flange. If you have 2 piece axle shafts which are fine, do you have to replace them for the axle seal? Is it the seal which has worn out or something more dramatic that requires new axle shafts?
If I was having to replace the 2 peice axle shafts, say because one had spun its flange, I would strongly consider single piece axle shafts. I didn't last time due to cost and delivery times.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 9 Old 05-21-2015, 07:45 AM
WindKnot
1977 CJ7
If the two piece axles are damaged, I'd definitely go with one piece replacements. Otherwise, what Bagus said.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #5 of 9 Old 05-22-2015, 12:17 PM
Colt44
1983 CJ7
I've owned my '83 since 2006 with no axle problems.
I'm more concerned about the AMC 20 unit itself and plan to weld and brace the tubes.
If and when I have issues with the axles I'll definitely upgrade to one-piece units.
"We are all of us in the gutter...
Some of us are looking at the stars."
~ Oscar Wilde via Chrissie Hynde
Colt44 is offline
post #6 of 9 Old 05-22-2015, 04:10 PM
ctorj
1977 CJ7
Bagus is correct I just last year replaced my 2 piece because of seals and bearings were shot. They never spun with 31 inch tires with over 200K miles on them. About half if not more where mostly on forest service roads. They also spent about 5K miles behind a turned up cummins 4bt and 33s. When I replaced them it was only 30 bucks more for moser one piece axles (they were on sale).
So you cant go wrong with 2 piece axles unless you don't torque them down fully. Yes one piece axles are worth the money if they are not much more. The piece of mind is very nice.
1977 CJ7. 3.9 Cummins 4BT, ZF5, Dana 300, SOA
ctorj is offline
post #7 of 9 Old 05-26-2015, 12:51 PM Thread Starter
herb812
1983 CJ7
Going to stick with 2 piece (for now). And replace seals. Thanks
herb812 is offline
post #8 of 9 Old 05-26-2015, 01:05 PM
Fourtrail
1974 CJ6
Be sure to get the 250+ ft/lbs of torque on the axle nut when reassembling or you will be buying 1 piece axles sooner than later.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #9 of 9 Old 05-26-2015, 03:19 PM
keith460
Jeep. There's Only One
keith460's Avatar
And I might add, when tightening the nut, make sure you have the tire on. I made the mistake of fabricating a tool to hold the axle flange from turning during the nut tightening procedure and bent my flange. Had to replace with a new one and made sure the tire was on as spelled out in the FSM.
1984 CJ-7 Renegade
keith460 is offline
