1 Inch Body Lift Now No It Wont Go Into Gear - JeepForum.com
post #1 of 7 Old 01-18-2010, 10:41 AM Thread Starter
stang-4
1982 CJ8
HELLO New here...well beeen lurking forever,,I installed a 1 inch body lift on my 82 scrambler and now wont go into gear. I tried adjusting the linkage under the hood but no luck. IF I HOLD THE LINKAGE UNDER THE HOOD AND HAVE A BUDDY MOVE THE SHIFTER ON THE COLUMN I GET NO MOVEMENT DOWN BELOW. IT ALL WORKED PERFECT BEFORE THE LIFT. ANY SUGGESTION ?
stang-4 is offline
post #2 of 7 Old 01-18-2010, 10:53 AM
Jeepican
1976 CJ5
Take the lift off
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline
post #3 of 7 Old 01-18-2010, 11:41 AM
gotCLAY
You broke the linkage some where when you jacked up the body. most of the time it brakes right where it comes out of the ster/colm. Start at the trans and follow it up.
GOOD LUCK & GOD BLESS
gotCLAY is offline
post #4 of 7 Old 01-18-2010, 12:15 PM Thread Starter
stang-4
1982 CJ8
thanks linkage from main rod down to trans is working good...disconnected it from the column and goes into all gears.....where the rod from the trans attaches is where the problem begins...you can hold the ear but when you move the shift lever on the colum nothing moves..... going the shop tonight to double check everything while it's still on the lift
stang-4 is offline
post #5 of 7 Old 01-22-2010, 02:29 AM Thread Starter
stang-4
1982 CJ8
bump ^^^^^^
stang-4 is offline
post #6 of 7 Old 01-22-2010, 07:28 AM
joes1982CJ
Originally Posted by stang-4 View Post
bump ^^^^^^
how big of a body lift?
joes1982CJ is offline
post #7 of 7 Old 01-22-2010, 10:19 AM
Jeepican
1976 CJ5
Title says 1
-Barney Fife-
Jeepican is offline
1 inch body lift and 3/4 inch shackle lift? bucs1fan Jeep CJ Forum 6 09-29-2009 12:21 PM
1 inch body lift jallen760 Jeep CJ Forum 5 10-25-2008 12:21 PM
Any tricks to do 3 inch body lift? XcessiveRebel Jeep CJ Forum 4 07-04-2004 10:18 PM
What do i need to change when i add a three inch body lift jeepcj7 Jeep CJ Forum 2 03-14-2003 10:51 PM
2 inch body lift crotz83 Jeep CJ Forum 4 12-17-2002 06:25 PM
