1 inch body lift and 3/4 inch shackle lift? - JeepForum.com
post #1 of 7 Old 09-26-2009, 10:55 AM Thread Starter
bucs1fan
is this a good idea to get the 1inch body lift (Daystar Body Bushings) and a 3/4 inch lift (Daystar Shackles)? Will this mess up anything, bad idea, need new srings, shocks, or anything else I should be aware of?
bucs1fan is offline
post #2 of 7 Old 09-26-2009, 11:01 AM
oteps
1980 CJ5
You should be ok. The body lift, you might run into problems removing the old bolts. The shackle lift is a small one, I wouldnt go any bigger on that. They should be 1 1/2 longer than the stock ones, and probably stronger.
oteps is offline
post #3 of 7 Old 09-26-2009, 12:24 PM
gojeepin
1983 CJ7
Whe you put on the body lift you may need to lengthen your gas tank fill and vent, lower your radiator cowl, and change the bracketry on your clutch to ensure it doesn't fall off.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #4 of 7 Old 09-26-2009, 07:37 PM Thread Starter
bucs1fan
Man all that stuff for just for a little lift? Thats not even worth it then.
bucs1fan is offline
post #5 of 7 Old 09-26-2009, 07:39 PM
gojeepin
1983 CJ7
It is if you need that inch.
gojeepin is offline
post #6 of 7 Old 09-29-2009, 10:23 AM
datmony
It is pretty easy to do and worth it in spades because it keeps the center of gravity low and it allows you to still run larger tires. I would skip the shackle lift and get some springs to give you a bit more lift.
datmony is offline
post #7 of 7 Old 09-29-2009, 01:21 PM
OlivergreenCJ7
What size tire do you want to run and do you off road your jeep? If your looking for a size or to you can cut for TJ flares. Adds a lot of room. The front is hard to make it look good or you can flat fender it when you screw it up like I did
OlivergreenCJ7 is offline
1" inch shackle lift to accomodate 33s jeepguy85 Jeep CJ Forum 13 01-10-2009 07:04 AM
1 inch body lift jallen760 Jeep CJ Forum 5 10-25-2008 01:21 PM
4.5" Lift and 1 inch body 83 CJ5 Jeff5886 Jeep CJ Forum 3 10-03-2007 06:24 PM
Any tricks to do 3 inch body lift? XcessiveRebel Jeep CJ Forum 4 07-04-2004 11:18 PM
2 inch body lift crotz83 Jeep CJ Forum 4 12-17-2002 07:25 PM
