1/4 or 5/16 return line? - JeepForum.com
post #1 of 6 Old 09-10-2012, 08:20 PM Thread Starter
sertshark
The nipple for the return fuel line is 5/16" on the TBI, but the return line is 1/4". I have read quite a few reports that say, contrary to what some believe, using the stock 1/4" return line caused no issues. Since the nipple for the return line on the Howell kit is 5/16", I have a few issues:
1) I am having a lot of trouble finding an adapter from 1/4 to 5/16. The more I look, the more I wonder if maybe they are hard to find because it wouldn't be a good idea to have one. Anyone know if they are made?
2) Anyone have ideas on where to purchase the return line, that is if I decide to replace the whole return with 5/16? I really don't want to spend a lot of money where I don't really need to. I would rather spend the money on something else I really need, rather than changing the line if I don't really need to. If I go this route, then #1 above would still apply (for the sending unit side of the hose).
3) If you have a Howell with stock return, how did you attach yours?
Thank you.
Year/Model: '86 CJ7 - Engine: 258 I-6 - Lift: Pro Comp 4" - Tires: 33X12.5 - Nuttered - Team Rush'd - Howell TBI
sertshark is offline
post #2 of 6 Old 09-10-2012, 09:36 PM
zillla
1930 VJ
I do not have Howell but just installed an AFI system which is the same thing . .. I used the OEM 1/4" line.. As I recall I used a 5'16" hose and just clamped it tight with a small hose clamp.. The return side as i recall only sees about 4 lbs pressure. I also installed an in-tank pump after numerous vapor lock issues.. . Other than pinching the return line at the tank I had no other issues..
zillla is offline
post #3 of 6 Old 09-10-2012, 10:43 PM
BagusJeep
1981 CJ7
The hose for the stock return line is 0.25" ID. In other words the outside of the Tube going back to the tank is 0.25" OD.
You could use 0.25" ID hose to connect and it may be possible to work it over the nipple, it depends on the hose material. Alternatively you could look at the amount of flare on the Tube.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 6 Old 09-11-2012, 06:08 AM Thread Starter
sertshark
I think I'm gonna try and use 5/16 line and see if it will clamp down on it. I was hoping there may be a better solution, but maybe that will work.
post #5 of 6 Old 09-11-2012, 01:01 PM
84scrambler
1984 CJ8
I had a hell of a time finding correct adapters between the rubber fuel lines and the hard lines on my Jeep. The automotive industry really likes using 1/16" increments for there stuff. Good examples are 5/16 fuel lines and 9/16 suspension bolts. Most hardware stores carry a small inventory at those sizes but there is stuff out there that exists.
I found the company below that makes splice adapters, but I thought that was a little on the ghetto side.
http://www.plumbingsupply.com/barb.html
I ended up using Mcmaster Carr and ordered a 1/4" compression fitting to female NPT and then ordered a male NPT to the correct barb that I needed. It turned really clean and it gives you a lot of options for going with other tube and hose combinations. It also keeps everything looking the same.
Ohh and the 1/4" return is no problem. I ran it on my 4.3 cpi for about 6 years.
84scrambler is offline
post #6 of 6 Old 09-11-2012, 02:40 PM
248107
Guest
1983 CJ7
I've had mine on since 96 with no issues.Just clamp the 5/16 over it.Double clamp it if you have too.
248107 is offline
is the a need for a return line or vapor line? st3dnut Jeep CJ Forum 9 07-13-2010 08:47 PM
Fuel Return Line specwarCJ Jeep CJ Forum 11 03-24-2010 08:45 PM
Gas line return SonicR1 Jeep CJ Forum 4 03-04-2010 08:35 PM
Which line is transmission line feed and return on radiator? sweet76 Jeep CJ Forum 4 01-01-2010 08:45 AM
CJ7 Fuel Return Line for TBI jfwireless Jeep CJ Forum 7 05-17-2007 09:37 PM
