N23 Recall Issue? No 4-Low! ********SURVEY******* - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Jeep Recalls > N23 Recall Issue? No 4-Low! ********SURVEY*******
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave 17.76% for the 4th of july with ruffstuff specialtiesJuly 4th Sale Event! and Yes, We're Open!
View Poll Results: Has the N23 recall been successful on your vehicle?
Yes, the recall was performed without issue. I have shifted into 4x4 Low multiple times. 38 9.00%
Yes, the recall was performed but I had to have the actuator replaced. FREE OF CHARGE 28 6.64%
Yes, the recall was performed but I had to have the actuator replaced. PAID FOR REPAIR 11 2.61%
No, the recall was performed and my service 4wd light is on. 230 54.50%
I will not be getting the recall performed due to the problems. 115 27.25%
Voters: 422. You may not vote on this poll
Unread 12-09-2013, 04:18 PM   #1
nychaze
2010 XK Commander
This is a survey to determine the # of people that have had issues with the N23 recall.
People have reported that there service 4wd message has come on within days or weeks of having the recall performed. The message disables being able to shift into 4x4 LOW.
In cases the dealerships have replaced actuators to have the issue happen again.
The only known fix at the time is to clear the codes which will allow the system to operate correctly for a hours/days/weeks.
Jeep dealerships and the customer service branch have no knowledged that there is a correlation between the recall and the service 4wd issues and have been charging some for the fixes others they say are cover under warranty.
Please answer the survey below:
nychaze is offline   Reply With Quote Quick reply to this message
Unread 12-09-2013, 04:23 PM   #2
nychaze
2010 XK Commander
Meant to add another option:
No, actuator was replaced but my service 4wd message is still on.
If you have that problem, select NO and post your problem below.
Unread 12-09-2013, 04:34 PM   #3
ASTMedic
Had service done. Got service 4wd message and I'm going to the dealer this week. Will post more later
ASTMedic is offline   Reply With Quote Quick reply to this message
Unread 12-09-2013, 06:40 PM   #4
hawgripper
2008 WK
had the recall done and the message for 4WD low came on, went back to the dealer and had them clear the code 3 times and haven't had an issue since and that was a month ago with multiple runs now in 4 low.
hawgripper is offline   Reply With Quote Quick reply to this message
Unread 12-09-2013, 06:50 PM   #5
maloj2003wj
2006 WK
had recall done. Service 4wd message still came on. Cleared codes 3 times with superchips about 2 weeks ago. No issue so far.
2006 WK LIMITED|5.7 HEMI
maloj2003wj is offline   Reply With Quote Quick reply to this message
Unread 12-09-2013, 07:05 PM   #6
jjarvis0007
2005 WK
Should be another choice for the same problem after multiple actuators being changed. Its been done twice on mine. Still no 4low
jjarvis0007 is offline   Reply With Quote Quick reply to this message
Unread 12-09-2013, 08:47 PM   #7
Rockin1
2006 XK Commander
Had actuator replaced free, lasted 2 months
Rockin1 is offline   Reply With Quote Quick reply to this message
Unread 12-10-2013, 07:22 AM   #8
ducktail
2009 WK
They did a recall service. The first time I needed the 4wd Lo I did not have it. The dealer says there is corrosion on the actuator. Actuator is on backorder. Supposedly covered under extended warranty. We'll see what happens next. I will be driving in ordinary drive while waiting on the part.
2009 GC Limited. 265 70 18 is the only change to date. Bought some Rubicon 17" wheels and put BFG M/T's on for hunting season OME HD Front, OME MD rear, winch to come, basket and lights bars first
ducktail is offline   Reply With Quote Quick reply to this message
Unread 12-10-2013, 07:23 AM   #9
ducktail
2009 WK
You should not have to be doing that.
Unread 12-10-2013, 08:06 AM   #10
nychaze
2010 XK Commander
I know but I can't edit the poll.
If you have this problem please leave a post and select the NO option...sorry about that.
This will give us a better idea of the number of people effected since jeep thinks everyone they see is a special case.
Sent from AutoGuide.com Free App
Unread 12-10-2013, 10:27 AM   #11
bmac13579
2007 WK
Being the reserved, and safe person I typically am, I decided to get the N23 recall done.
Needless to say, it didn't work the first time and kept getting the 'Service 4-Wheel Drive' error message.
I took it back to the dealer with the N23 Recall Procedure and told them that it needs to be fixed.
The dealer performed the recall again and it seemed to work.....well.....only for a couple of days.
I took it back to the dealer and told them my 4Low wasnt working again and they said they could hook it up to the computer and look for codes but it would cost at least $50 to just hook it up.
I gave in and told them to do it.
And with my luck, the dealer's uplink to Chrysler went down. So I just got my WK back and went home.
It visit didn't cost anything, but I didn't get to figure out what's going on.
My next attempt is to just replace the actuator myself, but I don't think I should have to pay for a new actuator considering its Chrysler's fault that it doesn't work any more.
2007 WK - Silver WK Club Member #71, 4.7L V8, 5 spd Auto, Autobot Decal (grfxedge.com), Aspen Creek Front Tow Shackles, Factory Tow Hitch
Check out more pictures and info here: www.mywk.tumblr.com
bmac13579 is offline   Reply With Quote Quick reply to this message
Unread 12-10-2013, 11:02 AM   #12
tnadanzig
tnadanzig's Avatar
2007 WK
Not getting it done anytime soon. I like my Jeeps to actually work. I keep them out of the hands of service techs. If I have a problem I will do it myself.
CB Engineering
CB-engineer.com
2008 3.0L CRD WK LTD - Wifes, GDE DPF Delete Tune, Turbo Resonator Delete, 3" Intercooler, Addcoo Rear Sway Bar, 3.07 gears
2007 3.0L CRD WK LTD - Stage 2 Custom Spooling Tune, Go Fast Parts
Pro-lite Build
2003 F250 6.0L CCLB - Gearhead Tunes
tnadanzig is offline   Reply With Quote Quick reply to this message
Unread 12-10-2013, 11:48 AM   #13
ASTMedic
Bmac,
Replacing the actuator isn't going to fix it either. It's a faulty error code and the only soulution is to keep clearing it to allow the actuator to work. The software is the problem not hardware.
Unread 12-10-2013, 12:09 PM   #14
ducktail
2009 WK
I am told the actuator is on backorderl until Feb of 2014
Unread 12-10-2013, 03:09 PM   #15
road_tripper
recall done, waited for actuator, dealer installed new actuator... 2 weeks later 'service 4wd system'
road_tripper is offline   Reply With Quote Quick reply to this message
