N23 Recall Issue? No 4-Low! - Page 8 - JeepForum.com
 19Likes
post #106 of 4895 Old 09-24-2013, 05:26 PM
MoparMech
1995 XJ Cherokee
Before you guys replace any tcase sensors or motors check the tcase connector for corrosion. They turn green and do all sorts of wierd things.
MoparMech is offline
post #107 of 4895 Old 09-24-2013, 05:41 PM
jjarvis0007
2005 WK
I'll look at it but it worked just fine before
jjarvis0007 is offline
post #108 of 4895 Old 09-24-2013, 06:13 PM
Hemily_GC
2005 WK
Originally Posted by jjarvis0007
So taking it to Landers this week isn't a good idea.
No that still might be the thing to do if that was your plans. I took mine to classic in Texarkana because it was closer since I moved.
05 WK Grand Cherokee 5.7 Hemi!!!! QD II
Hemily_GC is offline
post #109 of 4895 Old 09-24-2013, 10:22 PM
RockinR
2006 XK Commander
Originally Posted by Beeracuda View Post
Well, it didn't stay fixed for long. I just got off the phone with the SM. He said he is going to make some phone calls. He said it was the first he had heard of the problem. I told him his was apparently pretty widespread. I'd be willing to bet if everybody actually checked their 4WD Low after the flash, there would be a lot more reports. How many people actually use their 4WD Low?
Doesn't really matter how many times you use 4Lo, if at all. The point is you paid for a 4WD vehicle and it should work.
RockinR is offline
post #110 of 4895 Old 09-25-2013, 07:54 PM
Beeracuda
2006 WK
Exactly!!!
2006 Grand Cherokee Overland, bone stock...for now.
The Beeracuda:
Beeracuda is offline
post #111 of 4895 Old 09-28-2013, 04:05 AM
DirtAddsHP
2007 WK
Originally Posted by jjarvis0007 View Post
Yes it is crappy. Someone is going to pay for mine other then me though. Not right they will fix it if you have warranty bc if the recall but with no warranty you're screwed.
wait... so if you do not have a warranty they want to charge to fix a recalled part? That is madness....
DirtAddsHP is offline
post #112 of 4895 Old 09-28-2013, 07:23 AM
GermantownJeep
The part hasn't been recalled. That's the issue. The N23 recall is like a software update. The actuators are failing AFTER the update, but so far Chrysler refuses to admit the two are related. They act like it's just a huge effing coincidence.
When mine was in the second time, the SM was all "I've got another one here with the same issue. I've got a call into Chrysler to see what's going on." Then when I picked it up he had changed his tune: "It wasn't related to the recall. It was just one if those things." Yeah, good answer.
My 2010 still had the powertrain warranty, so they fixed it for free and I didn't argue. If it's expired, get ready for a fight. Or just hold off for now and keep using your parking brake.
1995 Wrangler Rio Grande: RE 4.5" Lift, 33" MT/R's
2010 Grand Cherokee Limited: Hemi, QD II, 30" Nitto Terra Grapplers
GermantownJeep is offline
post #113 of 4895 Old 09-28-2013, 07:56 AM
CT05WK
Just figured out I have the same issue AFTER the recall "fix" what is this going to cost me?
The cocky SOB at the stealership said the toe have no correlation. I find that hard to believe. What do I do guys?
CT05WK is offline
post #114 of 4895 Old 09-28-2013, 10:47 AM
jjarvis0007
2005 WK
If you call and be persistent with them they should get things right. I had to call Chrysler and the service manager multiple times. The service manager where I am actually has the same problem on his Jeep that we've experienced and is getting his fixed with a new actuator
post #115 of 4895 Old 09-29-2013, 05:54 PM
xjtrailrider
I did not read all 8 pages but I had my recall done on my 09 Hemi XK with QD2 and now I get "service 4wd soon" when cranking the engine and if I try to put the t-case in 4-low it will not go in, even with the tranny in "N". My 09 has 38,000 miles on it and I have the lifetime power train warranty.
If I take it back for this will the repair be covered by the warranty?
xjtrailrider is offline
post #116 of 4895 Old 09-29-2013, 06:03 PM
CT05WK
I spoke to a jeep tech at a different dealership then the one that performed my recall flash. He said that the recall should state that if the 4WD does not work after the recall is fixed, the dealer must fix it. Guess I'll be reading the fine print.
CT05WK is offline
post #117 of 4895 Old 09-29-2013, 06:40 PM
onlyone
onlyone's Avatar
2014 JK Wrangler
Yes, they fixed mine under the lifetime warranty. Same problem.
Thank you Jesus
2014 Wrangler Sport 1.5" spacers in front .75 rear, 1" BL 255/80/17 BFG KM2
onlyone is offline
post #118 of 4895 Old 09-29-2013, 06:49 PM
CT05WK
Lifetime warranty?
CT05WK is offline
post #119 of 4895 Old 09-29-2013, 07:36 PM
stipo
2010 WK
My 2010 5.7 HEMI Overland would not start this morning. I called road service, they said they couldn't get it started either. I have the "Service the 4wd System " warning in the dash. Spoke to dealer, my warranty is out by 3 months, they are seeing what they can do to help. I've also contacted the Chrysler head office in Melbourne (Australia) to see what they can do (I was on the phone to Tracee at the head office customer service centre just last Thursday to see what the story was on the Final Drive Controller recall. & now this.) All I can do is wait & see what happens.
stipo is offline
post #120 of 4895 Old 09-29-2013, 07:52 PM
xjtrailrider
Thanks!
Originally Posted by CT05WK View Post
Lifetime warranty?
Yes! When I bought my XK in 09 they offered a lifetime power-train warranty as an incentive to buy it. I also have a lifetime power-train warranty on my 08 JK Sahara. They have stood by the JK very well as it has issues(what JK doesn't!) but the XK has been flawless until now. Here comes the acid test!
error , recall
