N23 Recall Issue? No 4-Low! - Page 7 - JeepForum.com
 13Likes
post #91 of 4866 Old 09-23-2013, 04:47 PM
WKDiesel
2 Weeks for a new FDM to arrive. I wonder if the FDM and Actuator are actually the same part.
WKDiesel is offline
post #92 of 4866 Old 09-23-2013, 04:58 PM
Hemily_GC
2005 WK
Originally Posted by jjarvis0007
What did they say?
When i called to check earlier they said they were still running diagnostics.. Hopefully find out tomorrow. I see your from NLR can I ask what dealer your dealing with? I've used landers in benton for service work before and been very pleased but that was for my wife's charger.
05 WK Grand Cherokee 5.7 Hemi!!!! QD II
Hemily_GC is offline
post #93 of 4866 Old 09-23-2013, 05:19 PM
jjarvis0007
2005 WK
I have been using Fletcher Dodge Jeep in Sherwood. I've heard to take it to Landers if I want it done right though.
jjarvis0007 is offline
post #94 of 4866 Old 09-24-2013, 10:56 AM
sickchilly
2010 WK
Just retuned from the dealer. Only took about 29 minutes. They were not meticulous about following steps 15/16. They got it right this time. They tested it three times and I tested itself before driving off. All's well now it seems. I'll check it in a week or two again to be sure!
2010 Brilliant Black Crystal Pearl Coat Grand Cherokee S-Limited with various bits 'n pieces... broken in but not even finished!
sickchilly is online now
post #95 of 4866 Old 09-24-2013, 11:00 AM
jjarvis0007
2005 WK
I would check it everyday. First time mine lasted about a week then the second times a couple days. The third time it lasted a day. Now no 4low
post #96 of 4866 Old 09-24-2013, 11:05 AM
Trisalsa
Trisalsa's Avatar
So far so good. First time in, the update didn't work. Brought it back to the dealership and they spent a good hour on it. Said they ended up resetting the computer before everything started working correctly. Been about two weeks now and still no problems. Got the Commander used and wonder if someone had a different tune on the computer because the shift points seem cleaner now and mileage a bit better which the update shouldn't have effected, but the reset could have.
1999 TJ Sport
2010 XK Limited 5.7
Trisalsa is offline
post #97 of 4866 Old 09-24-2013, 01:12 PM
Beeracuda
2006 WK
Originally Posted by Beeracuda View Post
I took mine in for another reflash today. 4 Low worked when I got it home. We will see if it stays fixed.
Well, it didn't stay fixed for long. I just got off the phone with the SM. He said he is going to make some phone calls. He said it was the first he had heard of the problem. I told him his was apparently pretty widespread. I'd be willing to bet if everybody actually checked their 4WD Low after the flash, there would be a lot more reports. How many people actually use their 4WD Low?
2006 Grand Cherokee Overland, bone stock...for now.
The Beeracuda:
Beeracuda is offline
post #98 of 4866 Old 09-24-2013, 01:30 PM
WKDiesel
I think in most cases people never use 4lo. Except the people on this forum. Most people buy a jeep and drive it as a commuter car.
That's probably what Chrysler was hoping for.
It's all a numbers game unfortunately.
Crappy for us the customers.
WKDiesel is offline
post #99 of 4866 Old 09-24-2013, 01:44 PM
jjarvis0007
2005 WK
Yes it is crappy. Someone is going to pay for mine other then me though. Not right they will fix it if you have warranty bc if the recall but with no warranty you're screwed.
post #100 of 4866 Old 09-24-2013, 01:54 PM
sickchilly
2010 WK
Kinda makes me miss the manual transfer case linkage in my JKs. Oh right, those plastic clips broke all the time too leaving you stuck in 4-Lo!
post #101 of 4866 Old 09-24-2013, 02:16 PM
BlueSteelJP
2005 WK
It was very interesting to see this thread, same thing happened to me right after the recall was performed. They replaced the actuator is back in working order again. Thought it was just a fluke or my luck.
Blue WK Club Member #10
2005 Jeep Grand Cherokee Limited, 5.7 Liter Hemi no Mods So Far.
BlueSteelJP is offline
post #102 of 4866 Old 09-24-2013, 02:30 PM
jjarvis0007
2005 WK
Guess you had warranty?
post #103 of 4866 Old 09-24-2013, 05:04 PM
Hemily_GC
2005 WK
Got a call back from the service dept. today at 5 reassuring me they hadn't forgot about me and that they had started a case with Chrysler because they had no clue what was going on with my jeep.
post #104 of 4866 Old 09-24-2013, 05:18 PM
WKDiesel
Clearly it seems like Chrysler researched the issue long enough before they issued the recall.
I'm an Micro-Electronics Engineer by training and a cracked circuit board is a cracked circuit board. Since circuit boards are multi-layer designs now. Every crack probably affects different branches of circuits. It's a flawed design and that's why it's probably broken.
The only real fix is to redesigned the crack board. I hope Chrysler does it's customers right and replace all the bad FDCM.
This is what a lot of manufacturers are switching to now. Eliminate the Circuit board = No more cracking.
WKDiesel is offline
post #105 of 4866 Old 09-24-2013, 05:19 PM
jjarvis0007
2005 WK
So taking it to Landers this week isn't a good idea.
error , recall
