N23 Recall Issue? No 4-Low! - Page 259 - JeepForum.com
 19Likes
post #3871 of 4895 Old 08-26-2014, 08:15 PM
RVThere
2008 WK
Originally Posted by Jtav2012 View Post
I know its just anecdotal evidence but I replaced my 199AJ with a 199AL and haven't had anything strange happen for 2 months (except for my 4lo and neutral working properly, so weird...)
So if you can find one that's close, even if it isn't 1-letter off, it might be worth a shot.
http://www.jeepforum.com/forum/f67/n...l#post23914562
Totally agree if you find a pre-N23 FDCM that has a letter that is AFTER the letter on your current FDCM. Problems arise when you try to use an older pre-N23 FDCM that has a letter that is BEFORE the one that came with the Jeep.
RVThere is offline
post #3872 of 4895 Old 08-27-2014, 02:07 AM
chmo
Or you are lucky ...
My 199AM got replaced by a 199AK (coming from a same spec Limited!) ... all working fine ... no lights at all.
"The more I know, the more I realize how much I don't know"
chmo is offline
post #3873 of 4895 Old 08-27-2014, 06:20 AM
Clach
2006 WK
Interesting..Service message appeared (once) on start up but 4lo continues to work...so far, after 29/7 update!
Clach is offline
post #3874 of 4895 Old 08-27-2014, 10:46 AM
allmuddled
Jeep UK are now able to confirm that N23 caused problems.
I know this is old information, but I was given service bulletin: 21-022-14 and was told to book with the dealership and jeep would reimburse the re-flash.
Question: Has anyone gone back since and had the new flash applied (from service bulletin 21-022-14) ? Was it successful?
I am now 1 months since last fuse pull.
Caveat > If this re-flash doesn't fix it 'something else is wrong and you will need to pay for any further diagnostics
allmuddled is offline
post #3875 of 4895 Old 08-27-2014, 11:36 AM
Craigyfm
2006 WK
The saga continues.... I've had a new actuator, old FDCM replaced with one from breaker, pre-flash. The truck has just driven across Europe with no issues. Uk to East Germany. The truck has also had every fluid changed as part of the 80k service and low and behold, service 4wd light has come on at motorway speeds. The light goes off after I slow to 50-60 mph, and drives perfectly. I've read that a ground wire may cause this but don't know where to look, the common denominator is the speed as it's happened twice on the motorway. Also, could the transfer case fluid be expanding when driving and causing this... Please someone help as this is driving me off my head and I'm now paying out of my own pocket. Any advice on wires to be checked would be excellent. I can see a Landrover with my name on it............. This must be causing a lot of Jeep drivers to switch allegiance at a rapid rate.
Craigyfm is offline
post #3876 of 4895 Old 08-27-2014, 11:46 AM
Jtav2012
2005 WK
This sounds unrelated to the N23 recall, either the techs messed something up when they put the new actuator in or you have a different issue
Not-stock 2005 5.7L WK
Jtav2012 is offline
post #3877 of 4895 Old 08-28-2014, 06:22 AM
Eigen48
2006 XK Commander
So yesterday I tried the fuse (#25) pull trick and it worked
Went right into 4WD LO. I even turned the engine off and back on tried it again and still worked. I will test it every day now.
Jeep Commander 06 4.7L Trail Rated again.
Eigen48 is offline
post #3878 of 4895 Old 08-28-2014, 02:16 PM
BJMOLD
2010 WK
Had the new software update done three weeks ago plus new actuator.The low 4x4 has now been cycled around 140 times since then and all ok.The Jeep tech who I know said its imperative to do the update as per TSB .I am still cynical.I think pigs will fly before another recall over this problem.This still seems to be treated by FC on a case by case basis.I wasnt even contacted by my dealer re recent updates.There would be many 1000s of owners who wouldnt even know they had no low range..
BJMOLD is offline
post #3879 of 4895 Old 08-28-2014, 02:59 PM
johngreen1234
2010 WK
I agree with this. Read a recent article that said recalls are now a major profit source for dealers. The very few owners who will never buy that brand is offest by the owners who trade the old bad car in on a new (bad) car.
And as for the recall service revenue, anyone who was coerced into shelling out $800 for an actuator to fix the faulty recall knows what profit means. Thank you Chrysler!
johngreen1234 is offline
post #3880 of 4895 Old 08-29-2014, 07:58 PM
amcfanatic
2009 WK
Originally Posted by johngreen1234 View Post
. . . recalls are now a major profit source for dealers.
And they also wanted me to pay 50% of a new wiring harness. He said it as if he was giving me a real deal.
09 Overland 5.7 Hemi
98 5.9 Limited
80 CJ7
amcfanatic is offline
post #3881 of 4895 Old 08-29-2014, 08:39 PM
johnevans3
2006 WK
Craigyfm
Might check a wheel speed sensor. I had that problem. It would light up ABS, BAS, anti Skid and buck and sputter as if it has some bad gas. Should be a code stored to indicate that.
johnevans3 is offline
post #3882 of 4895 Old 08-30-2014, 06:20 AM
ZF1FR
2007 WK
199AM is the latest spec?
I have a 2005 3.0CRD, I can get a 199AM coming from a 2008 3.0CRD.
Should it be OK?
ZF1FR is offline
post #3883 of 4895 Old 08-30-2014, 09:40 AM
cmwotring
2008 WK
Day 1 after 7/29 update. So far so good.
cmwotring is offline
post #3884 of 4895 Old 08-30-2014, 10:58 AM
CavallinoRed
2006 WK
Should it be OK?
More dependent on matching the part number than the donor vehicle. If you have a 199AL or a 199AM now it should work fine.
Reports of using a FDCM other than matching or one letter after have been mixed.
I'm assuming you checked that the recall was outstanding on the car this came from.
CavallinoRed is offline
post #3885 of 4895 Old 08-30-2014, 01:06 PM
ZF1FR
2007 WK
Yes the FDCM was confirmed N23 free. So I still have to remove my rear seats to check. If it's a 199AK you think it might be risky?
ZF1FR is offline
error , recall
