N23 Recall Issue? No 4-Low! - Page 252 - JeepForum.com
 19Likes
post #3766 of 4895 Old 08-05-2014, 01:30 PM
kevinw2580
2008 WK
Originally Posted by esoxhntr View Post
It's fuse #33 on our CRDs. You can go in with the message still on, make sure they are aware of the July 29th revision.
Great! The fuse trick worked for me this time so the message is gone and the 4Lo is working for now.
But I'm not sure if I trust Chrysler with this new update... I think I'm going to wait a bit until they have truly corrected this MAJOR screw up
Btw, esoxhntr, what boat do you tow? I'm a salmon and bass guy, hailing a lund.
2008 Black WK S-Limited 3.0L Diesel
kevinw2580 is offline
post #3767 of 4895 Old 08-05-2014, 03:30 PM
WazzuCMGrad
2011 WK
Service Appointment held on 7/31/14. 7/29 TSB performed. This version has worked longer than the previous flash had done, but it hasn't even been a week yet.
I'm testing a few (2-3) times per day, so hopefully I'll either get tired of testing or it'll fail. My service manager seems highly confident that this will be the final fix, especially since they re-did the one that didn't work with the 7/29 update and had success.
WazzuCMGrad is offline
post #3768 of 4895 Old 08-05-2014, 03:41 PM
esoxhntr
2008 WK
I tow a mirrocraft with a yammy. Fish muskies pretty much exclusively except through the ice.
'97 XJ. 4.0. *sold*
'01 WJ. 4.7. *sold*
'08 WK CRD. *trade*
'17 Colorado 2.8 Diesel. CFT v4.0
esoxhntr is offline
post #3769 of 4895 Old 08-06-2014, 07:20 AM
emarrero
2015 KL Cherokee
I had no 4LO after N23 and took it into the dealership this week.
Today starts the third day they'll have my car and the service advisor just told me he replaced a wiring harness and will be replacing my actuator tomorrow. He says both things should be covered under N23.
While it stinks not having my car for three days I do have a loaner and I must say this service department seems to be doing the right thing.
Will keep you posted.
emarrero is offline
post #3770 of 4895 Old 08-06-2014, 06:27 PM
KIWICANADIAN1
2008 WK
Just had N23 recall done today
I went into the dealer last week as the engine check light was on and the message center was saying check 4x4 system. They went through a few things and advised me of the N23 recall which I had them do & as there was not enough time at the end of the day They gave me the option to com back this week to finish the service, they thought a wire was broken under the battery to the FDCM??? The check engine light was always on and I assumed it was due to the 4x4 message, apparently not as that was No 4 glow plug gone bad, so $65.15 for a new GP. They said there was nothing wrong with the 4x4 system everything worked OK but the "Module Under the battery" was at fault?? and would cost $405 for a new module, they would have to remove the battery, the left front tire and the inner fender to get to it????, I see here the FDCM is under the back seat. But the 4x4 is working fine, Hi range & Low Range, I even checked it in my driveway tonight, might try in the back yard tomorrow. I did not know of the problems everyone has had with this N23 & the broken circuit board "patch up" by FCA, seems like a major **up to me.
KIWICANADIAN1 is offline
post #3771 of 4895 Old 08-07-2014, 01:59 PM
BJMOLD
2010 WK
July 29th update is failing in OZ,
BJMOLD is offline
post #3772 of 4895 Old 08-07-2014, 04:20 PM
modette
2005 WK
You can get that update in Prison?
modette is offline
post #3773 of 4895 Old 08-07-2014, 10:26 PM
BJMOLD
2010 WK
You can get a lot of things in prison ,maybe a N23 fix.?
BJMOLD is offline
post #3774 of 4895 Old 08-08-2014, 07:48 AM
clemsonscj
2009 WK
I'd say their odds are about as good as ours...
'09 Grand Cherokee Overland 5.7L HEMI QUADRA-DRIVE II
Black WK Club #134
clemsonscj is offline
post #3775 of 4895 Old 08-08-2014, 08:18 AM
road_tripper
better than our odds if the inmates have a work-release program with the local auto recyclers
road_tripper is offline
post #3776 of 4895 Old 08-08-2014, 03:16 PM
clemsonscj
2009 WK
They might be who we're waiting on for the fix...
Black WK Club #134
post #3777 of 4895 Old 08-08-2014, 03:58 PM
modette
2005 WK
Hey I'm trying to figure out the problem on $2 an hour, give me a break
modette is offline
post #3778 of 4895 Old 08-08-2014, 06:21 PM
amcfanatic
2009 WK
If Chrysler had you and Blown7 were working on this, it would have been fixed a long time ago.
09 Overland 5.7 Hemi
98 5.9 Limited
80 CJ7
amcfanatic is offline
post #3779 of 4895 Old 08-08-2014, 10:10 PM
MrMischief
It's only been 3 days but the latest flash is working so far for me. I used 4 low 3 or 4 times today, also pulled it while in drive, reverse, cruising the road at 20 mph or so.... just to sorta "try everything" and really work the switch I guess. I'll keep reporting back.
MrMischief is offline
post #3780 of 4895 Old 08-09-2014, 09:17 AM
Clach
2006 WK
I had the July 29th update done today. It was working when I went in (fuse pull) so, lets see how long this lasts. For me, the fault normally appears on start up when I am travelling for more than 2 hours or 2/300 miles...
Clach is offline
error , recall
