N23 Recall Issue? No 4-Low! - Page 18 - JeepForum.com
 16Likes
post #256 of 4881 Old 10-29-2013, 08:20 PM
cherrybomb05
2010 JK Wrangler
Hope I don't have this problem - I recently did this recall at my dealership and now when I turn my jeep on it flashes Service 4wd System for a half second then disappears.
07 WK
10 JKUR
11 JKR
cherrybomb05 is offline
post #257 of 4881 Old 10-29-2013, 08:22 PM
zedtechus
2008 WK
Originally Posted by Scottso699 View Post
Hi - I am using the 3875 (which is now the 3870). As far as I know you can get one just about anywhere - I got mine on eBay used and paid the $100 unlock fee. Brand new they are $340? I love it.
Thanks for the info, I just tried to use my CanODB2 INNOVA 3100f, which is able to read DTC Transmission codes, but it didn't find any code even that I tried many times to lift up the 4lo lever and every time I'm getting the service 4wd mode message
I might need to buy one like yours.
Thanks again.
2008 GC CRD Laredo - QT II - Jeep Black with 18" chrome wheels
zedtechus is offline
post #258 of 4881 Old 10-29-2013, 08:32 PM
Scottso699
2006 WK
I had the same problem at first and then I tried to put it in 4 wheel low and the bells and whistles went off. You will probably have an issue. Sorry.
Scott
2006 WK Overland, OME HD Springs F&R, Bilstein 4600 Struts, 1.5" Rear Spacer, 265/70/r17 BFGs
Scottso699 is offline
post #259 of 4881 Old 10-29-2013, 08:35 PM
Scottso699
2006 WK
Originally Posted by zedtechus
Thanks for the info, I just tried to use my CanODB2 INNOVA 3100f, which is able to read DTC Transmission codes, but it didn't find any code even that I tried many times to lift up the 4lo lever and every time I'm getting the service 4wd mode message I might need to buy one like yours. Thanks again.
My obd2 code scanner didn't pick up these codes either - only the superchips tuner picked them up. Strange.
Scott
post #260 of 4881 Old 10-29-2013, 09:05 PM
cherrybomb05
2010 JK Wrangler
Yeah I just did after I went into the garage I figured - What the hell.
What do you know? Pull it into 4wd low and it says service 4wd system. DTC report still comes up blank though lol. Time to get my dealer to fix it, I'm going wheeling soon! D:
07 WK
10 JKUR
11 JKR
post #261 of 4881 Old 10-30-2013, 10:43 PM
Rockin1
2006 XK Commander
Ok I fixed my problem myself! I have a superchips programmer and used it to scan for codes and I got two - c140f and c1405. I figured before I take it back to the dealer tomorrow I will clear the codes to see if they come back. I clears them, started the car - pulled the 4 wheel low shifter - it went right to 4 wheel low with no issue! Unbelievable.... All I had to do was clear the code??? Just like the instructions for the recall state in step 15. My dealer is officially worthless. Superchips rules.
So from what I have been reading on the last 2 pages, those of us who had new shift actuators (motors) installed by the dealers were taken in by dealer scams just to make some easy money since the actuator replacement takes less than 30 minutes and is covered by Chrysler? And do you suppose the dealer clears the codes after changing the actuator needlessly, or do some actuators really go bad???
Rockin1 is offline
post #262 of 4881 Old 10-30-2013, 11:12 PM
Rockin1
2006 XK Commander
I ran across something interesting. A N23 recall letter highlighting the T-Case Actuator???
Rockin1 is offline
post #263 of 4881 Old 10-31-2013, 07:32 AM
Scottso699
2006 WK
I think that is exactly what is happening. The pompous service manager at the dealer I will never go to again insisted that there is no way the Recall programming could effect the 4 wheel low operation and attributes it to my shift motor going bad. Wanted to hear nothing about it being the fact that his techs did it the wrong way. Even when a rep from Chrysler called he still wanted to hear nothing about it. The Chrysler Rep recommended me going to a different dealer. Anyone in the Jersey Shore Area - avoid Pine Belt Jeep. The service Manager's name is Jack and he don't know jack!
Scott
post #264 of 4881 Old 10-31-2013, 07:38 AM
jjarvis0007
2005 WK
I'm at the Dealership for the 5th time now. 1st time back since the actuator install.
jjarvis0007 is offline
post #265 of 4881 Old 10-31-2013, 08:33 AM
Scottso699
2006 WK
Tell them to check for codes C140F and/or C1405.
Scott
post #266 of 4881 Old 10-31-2013, 12:55 PM
jjarvis0007
2005 WK
They say they've cleared them 3 times every time its in there.
post #267 of 4881 Old 10-31-2013, 01:01 PM
DVB
2006 WK
I haven't checked mine yet. I just bought my Jeep a couple months ago so I don't know if I would've gotten something in the mail. I'll check on the jeep site and enter my VIN, see what happens.
2006 4.7 Limited QD II, Stock
DVB is offline
post #268 of 4881 Old 10-31-2013, 01:26 PM
Scottso699
2006 WK
If you have a V-8 then you are part of the recall - all the V-8s have a 245 transfer case.
Scott
post #269 of 4881 Old 10-31-2013, 07:27 PM
jjarvis0007
2005 WK
Got my jeep back earlier. They installed another actuator. It works fine for now.
post #270 of 4881 Old 10-31-2013, 07:42 PM
cherrybomb05
2010 JK Wrangler
Just got mine reflashed today, still doesn't work. Getting new actuator, but they are on back order I guess.
07 WK
10 JKUR
11 JKR
error , recall
