N23 Recall Issue? No 4-Low! - JeepForum.com
 16Likes
post #1 of 4881 Old 08-13-2013, 12:11 PM Thread Starter
Umbrella
2006 XK Commander
I had the Commander (4.7L, QTII) in for the recall less than two weeks ago, dealer performed the "reprogram final drive controller" reflash.
This morning I went to use 4wd low (first time since reflash), and immediately got the "Service 4wd System" light. It did not engage 4-low.
Light disappears once vehicle is restarted but comes back immediately if I attempt to go to 4-low, and stays on until I turn it off and restart.
Has anyone else who has had the recall performed experienced this?
If you've had it done, you may want to check.
I have an appointment to have it looked at so we wll see what happens, and I will update as I learn more.
Check your 4-low before signing off on the repair/recall.
2006 XK 4.7 Limited
1995 XJ 4.0 Sport
Umbrella is offline
post #2 of 4881 Old 08-13-2013, 03:44 PM
ecollins7
2006 WK
Thank you so much for posting this! I never thought of checking this but sure enough, I get the same message.
ecollins7 is offline
post #3 of 4881 Old 08-13-2013, 06:20 PM Thread Starter
Umbrella
2006 XK Commander
Well that sucks.
2006 XK 4.7 Limited
1995 XJ 4.0 Sport
Umbrella is offline
post #4 of 4881 Old 08-13-2013, 07:41 PM
Megs_Revenge
2005 WK
Aww crap! Mine's at the dealership getting both the recall fixed AND a 4wd light issue fixed. Guess I'll have to call them tomorrow and make sure it works prior to them returning it. Thanks for the heads up!
2005 Silver WK 5.7L Hemi
Silver WK club #69
Oo|||||||oO
Megs_Revenge is offline
post #5 of 4881 Old 08-13-2013, 09:03 PM
Shafer57
2006 WK
I bet a lot of Jeeps will be going back, they're fixing it in summer so i'm assuming most Jeeps haven't even been put in 4LO yet (if ever).
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline
post #6 of 4881 Old 08-13-2013, 10:04 PM
fatfreddy
2008 WK
I am glad I read this.They are doing a software work around for a cracked PC board that controls the transfer case.The only way I will let them touch mine is when they agree to replace the module that controls the transfer case.This came up in a conversation I was having with an automotive tech I know.We had a good laugh about the software re-write to fix a cracked PC board.He worked for Chrysler for years and we had lots of laughs at the the way they did some recalls.We talked about how it could screw up the way the transfer case would work after the up date.I see from your posts that it did screw things up.
fatfreddy is offline
post #7 of 4881 Old 08-13-2013, 10:26 PM
sixfoot9psu
2005 WK
So Freddy, you aren't taking it in for the update? I was thinking about doing the same since they aren't even replacing the board
'05 GC 5.7L Hemi QDII...Rock Krawler lift, 4XGuard Matrix, rock sliders, front and rear skids, belly guard, rear diff guard, Bilstein HDs, Volant intake, 265/70 Goodyear DuraTracs, Superchips, Rola roof rack, BORA wheel spacers, Rocky Road Leveling Spacers, Magnaflow muffler, KC Slimlights, BT catch can, tb cover, and underhood kit, Expanded Sheet Metal Grille
'09 G8 GT 6.0L...Kooks Headers, Rotofab intake, SLP exhaust, Vector Motorsports Tune
sixfoot9psu is offline
post #8 of 4881 Old 08-14-2013, 09:18 AM
zc911
mine works fine?
zc911 is offline
post #9 of 4881 Old 08-14-2013, 09:32 AM
BobbyB_WK08
2008 WK
I received the letter in the mail and i thought i would go on the forum before i brought my jeep in for update. Looks like i will be opting not to get "software Update"
BobbyB_WK08 is offline
post #10 of 4881 Old 08-14-2013, 01:44 PM
trax95008
2006 XK Commander
Regardless if your 4WD is still functioning, (mine still works flawlessly) it's a safety concern. Lets say your jeep is sitting in your driveway and the T-case decides to shift into neutral, and your jeep rolls over your child! Will you then wish you had the recall performed?
trax95008 is offline
post #11 of 4881 Old 08-14-2013, 01:56 PM
sixfoot9psu
2005 WK
How many times has this actually happened to someone that caused the recall?
post #12 of 4881 Old 08-14-2013, 02:05 PM
dragginNCrds
2009 WK
the recall was performed on ours just before we got it.. and it works fine.. put it in 4lo the other day to load it on the rollback to go get windows tinted.. it was raining on the aluminum bed and all it wanted to do was spin.. so i locked it in 4lo and it climbed right up not a problem
dragginNCrds is offline
post #13 of 4881 Old 08-14-2013, 05:19 PM
giulio17
So should I get it done or not?
giulio17 is offline
post #14 of 4881 Old 08-14-2013, 05:42 PM
WmassWK
2006 WK
Mines goin in Fri morning... I'm gearing up for a fight.
WmassWK is offline
post #15 of 4881 Old 08-14-2013, 08:30 PM
GermantownJeep
Had the recall update done today. Tested 4Lo before and after. No issues so far. I'll be sure to keep an eye on it.
1995 Wrangler Rio Grande: RE 4.5" Lift, 33" MT/R's
2010 Grand Cherokee Limited: Hemi, QD II, 30" Nitto Terra Grapplers
GermantownJeep is offline
error , recall
