Zero steer - JeepForum.com
post #1 of 9 Old 11-18-2006, 11:06 AM Thread Starter
jeepramnauth
2010 JK Wrangler
Zero steer
Hey guys, I'm a mechanical engineering student and for one of my final projects in my CAD (catia) class I designed a zero-steer (found on the jeep hurricane) system. I have to state the practical uses for my design. So, I was just wondering if you guys could help me out. So the question basically is:
-How would such a system (turning 360 degrees in the same spot- zero turing radius) benifit off road driving?
jeepramnauth is offline
post #2 of 9 Old 11-18-2006, 11:23 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Well - the best thing I could think of as a practical use would be parking downtown. There are times that I have tried to park, and no matter what I did, my vehicle would not fit into the space.
Just to let you know, I have parked long-box trucks into spaces where there was only 2" of space between the front and rear of the truck by the time I was finished parking it. Ya - there might have been a couple of little "bumps" in the process, but nothing that would cause damage. In fact, I did that very thing last night parking between two of my other vehicles, just to see if I could do it. I did it!
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #3 of 9 Old 11-18-2006, 11:49 AM
JeepFreak91
if you get stuck in a dead end trail that isnt that wide, instead of backing up all the way or trying to turn around all you have to do is spin 180 degrees
JeepFreak91 is offline
post #4 of 9 Old 11-18-2006, 12:58 PM
ncb76
ncb76's Avatar
x2, especially when you've got a cliff face on one side and a 1000 ft. drop-off on the other.
"Let Freedom, Friendship, Faith thy Soul Engage,
And serve, like them, thy country and thy age."
'97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
ncb76 is offline
post #5 of 9 Old 11-18-2006, 02:45 PM Thread Starter
jeepramnauth
2010 JK Wrangler
thanks for the input guys, really appreciate it. keep um coming!
post #6 of 9 Old 11-18-2006, 03:14 PM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
The Hurricane's steering system is a marvel of engineering all by itself. There are multiple steering modes using four-wheel independent steering. That means that each wheel can turn separately from the others.
In standard steering mode, the rear wheels turn in the opposite direction to the front wheels, which tightens the turning radius and makes for more accurate steering. In a second mode, the rear wheels turn in the same direction as the front wheels, meaning the Hurricane can "crab-steer" -- move to the side without changing the direction that it faces.
A third mode, utilizing the "T-Box Zero Steer" mechanism, allows all four wheels to "toe-in" and changes the drive direction to each wheel so that they alternate. The result? The Jeep Hurricane has a turning radius of zero. The Hurricane can actually rotate in place.
Eh, i copied and pasted it, but closed the window before I could give proper referance.
I would say that the crab steer would be really helpful when your in the mud. If you're not getting anywhere you can creep to the side and hopefull get one sides tired onto the wall, aim for better lines, perform safer high speed lane changes, and I can see it being beneficial making maneuvers in the snow/ice.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #7 of 9 Old 11-18-2006, 07:07 PM
GreenDean
GreenDean's Avatar
after a night of drinking you can make all your friends puke with the tough of a button.
GreenDean is offline
post #8 of 9 Old 11-18-2006, 07:52 PM
arbby
2005 KJ Liberty
use it to do mad donuts in the parking lot...toss it into 1st and burnout donuts
|¯¯l,[___],
l---L--OlllllllO¬
()_) ()_)--o-)_)
Gone: 1993 YJ
arbby is offline
post #9 of 9 Old 11-18-2006, 08:07 PM
Slapahoe
Registered Jerk
Slapahoe's Avatar
I once went down a trail that was ment for ATV's. I didn't belive it at first untill the trail became VERY narrow and then finall came into a double s turn with a steep decline. I have to do almost a 20 point turn all the while with all the other guys standing on my rockers and passenger side to keep me from flipping. Had I had zero steer, I would of effortlessly turned around and been on with me day.
In the city, parellel parking difficulty would be a thing of the past.
93 YJ 4.0HO
'03 KJ Renegade
Slapahoe is offline
Thinking about a gun... steer me in the right direction the88thpianoman General Discussion 127 11-30-2008 08:36 PM
Bump Steer? 03Liberty General Discussion 0 04-24-2004 05:22 AM
