Windows 7 Upgrade Help! - Page 2 - JeepForum.com
post #16 of 31 Old 01-21-2010, 02:03 AM
jumbojeepman
1976 CJ7
Originally Posted by tjwoo View Post
hmm? you bought the upgrade disk when you're going from XP to 7?
Yep, and I'm up and running. Backed up the drive, and then did the easy transfer of my old files while I was at work tonight. Got home, stuck the 64 bit install disk in the drive, and booted from the disk. It installed remarkably fast (much faster than XP, by more than an hour.) I do, of course, have to reinstall all of my old programs, but I wanted to do that anyway (it's been awhile since I've cleaned up my system.) Now I'm waiting for the easy transfer to put all of my old files back on the disk.
I also put a better video card and finally ditched my 19" CRT monitor for a 23" LED.
jumbojeepman is offline
post #17 of 31 Old 01-21-2010, 03:42 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Originally Posted by Stoked99 View Post
My printer is fairly new so I think it will work. Why do you say you should have done 32 bit?
Unless I run some really powerful apps that needs more than 2GB of RAM it is essentially useless so the 32bit version would have been fine. Also drivers are easier to find since most Vista drivers will work in the Win7 OPSYS as I undertand it.....on the other hand eventually everything will be written for a 64bit OPSYS.
Thus far my old scanner won't work but new scanners are so cheap who cares. But my Adobe photoshop will not work in the 64bit environment and that hurt.....a lot.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #18 of 31 Old 01-21-2010, 03:47 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Originally Posted by igrok View Post
Windows 7 is the best operating system to come out of Redmond in my opinion. The 64bit version is faster, but harder to find drivers for everything.
It's almost good enough to keep me from booting into my Linux partition... NOT!
Originally Posted by jumbojeepman View Post
I'm starting my install right now. XP to Win7x64. I got the upgrade disk from Newegg.
I went from xp pro to win7 64 bit. I run a clean fast machine adding nothing unless necessary. WIN7 is fast compared to xp. It has a fresh look and once you get the feel for it it becomes quite user friendly. I also got my WIN7 from newegg.
post #19 of 31 Old 01-21-2010, 06:23 PM
johnniebravo
2008 WK
If you are having trouble with drivers for win7 64 bit, use vista 64bit drivers. They work fine. I used all vista 64 drivers on my windows server 2008 R2 build and all of them worked absolutely fine. In fact, I am still using a few of them despite new drivers being out.
BTW, server 2008 R2 is free to students via www.dreamspark.com. If you want a basic load with no fluff, this is it. My machine is running flawless as a workstation. The only catch is you'll need edit some programs to work on a server....and you'll need a server anti-virus.
2008 CRD GC
johnniebravo is offline
post #20 of 31 Old 01-21-2010, 06:54 PM
Kyoseki
Inconceivable!
Kyoseki's Avatar
If your machine is running Vista 64 perfectly well (and my workstation is), is there anything to be gained from switching to 7?
Due to lack of interest, tomorrow has been canceled
Kyoseki is offline
post #21 of 31 Old 01-21-2010, 09:26 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Actually no not right now. As long as MS supports Vista I would say you are good to go. I decided to go with WIN7 because my new laptop has WIN7 so I figured I would move up to WIN 7 on the desk top from XP pro.
The only driver I won't find is one for my old scanner and that is no big deal. In time it may get a driver written for it. I haven't looked for a VISTA driver for it yet but there may be one. I'll check it out when I get some time.....and I remember!
post #22 of 31 Old 01-21-2010, 09:32 PM
PhilipJ
PhilipJ's Avatar
If it runs fine then no, 7 isn't going to make you nerdgasm. The only major difference I've noticed is that 7 uses slightly less RAM than Vista. It's basically Vista Lite otherwise.
I miss Hold 'Em and Dreamscape though.
PhilipJ is offline
post #23 of 31 Old 01-21-2010, 11:12 PM
TJ311
I'd have to highly disagree. Windows 7 changes many many things to make for a much better user experience. It's MUCH snappier on the front end. I'm a Support Analyst and I've upgraded a few people in our organization to Vista (per their request, not mine) which gave myself and the customer many issues. When 7 was released, I didn't hesitate upgrading them to 7 and have not heard a peep from them since. These were all clean installs. I'm no fan boy but Windows 7 is definitely a fantastic product from MS. Worth the upgrade.
EDIT: I'll also add that it is usually worth the extra money and time to purchase a full install version rather than an upgrade if you can spring for it. Just my opinion though.
TJ311 is offline
post #24 of 31 Old 01-22-2010, 02:21 AM
jumbojeepman
1976 CJ7
Why? I did a full install from the upgrade disk, and saved about 1/2 off the price of the full install disk. I had no problems activating Windows 7 first time. I don't need the old copy of XP for anything, my laptop came with XP (I did the Win 7 upgrade on my desktop.)
post #25 of 31 Old 01-22-2010, 02:46 AM
Kyoseki
Inconceivable!
Kyoseki's Avatar
Indeed, it's my experience that upgrade disks simply ask you to verify the existence of the old one but you can perform a totally clean install.
I might still order a copy of Windows 7 just for the hell of it, but I'm in no rush.
I ordered a nice modular power supply, so I'm looking forward to getting that, the one I have has all kinds of stupid extra wires everywhere, I need to clean that **** up.
Kyoseki is offline
post #26 of 31 Old 01-22-2010, 07:08 AM
happymudder10
Funny how everyone wants the 64bit edition when 99.9% of people can't even tell the diffrence between the 32 and 64 bit versions. For me, I'll stick with Linux and keep telling Microsoft to shove it!
Just a traveling cat in a tall black hat riding a goat. Nothing to see here.
happymudder10 is offline
post #27 of 31 Old 01-22-2010, 02:22 PM
jumbojeepman
1976 CJ7
We are going to 64 bit now, knowing that it is the future of operating systems. More software will be written for 64 bit OS's in the coming years. I used XP for 8 years, I expect to use Win 7 the same period of time (I skip generations of OS, I had Win 98, XP and now 7, skipped 2000/ME and Vista.) The next version of Windows probably won't even have a 32 bit version. Besides, I wanted the use of all 4GB of memory I have in my system.
post #28 of 31 Old 01-22-2010, 02:50 PM
tjwoo
tjwoo's Avatar
you're so hip with your hip ways. you hip person you
tjwoo is offline
post #29 of 31 Old 01-22-2010, 02:51 PM
happymudder10
Cool, at least you skipped the bad versions, as for me, I do plan on installing the 64bit version of Ubuntu eventually. Maybe when I buy a new computer.
post #30 of 31 Old 01-22-2010, 03:24 PM
TJ311
I don't do upgrades but if that's how it works with just verifying the old key, then I could understand doing it.
As for the 32 vs 64, you're right, most won't know the difference. Unless you run a lot of VM's. I was given a MacPro at work and put Win 7 64 bit on it(exclusively). 2 Core 2 Quads and 8GB RAM runs all the VMs I need.
TJ311 is offline
windows 7 upgrade wont take mayor_bloom General Discussion 12 01-01-2010 04:37 PM
Bye Bye Windows XJLI General Discussion 8 11-05-2008 02:07 PM
Windows 95? XabuJr General Discussion 19 02-24-2008 12:11 AM
Windows XP help jtpaintball70 General Discussion 13 08-14-2006 09:23 PM
Windows Update make me log on to Windows FlyersFan2009 General Discussion 11 11-29-2005 07:04 PM
