Windows 7 Upgrade Help! - JeepForum.com
post #1 of 31 Old 01-20-2010, 07:58 PM Thread Starter
Stoked99
This is for the computer guys -
I'm getting ready to buy Windows 7 (Microsoft offers 7 Professional for $65 to college students) and I have a couple questions.
1. From what I've gathered, my wanting to go from 32 bit Vista to 64 bit 7 will require a clean install - that's fine. My question is, when I purchase the upgrade, it's a download. Can I do a clean install with a downloaded version?
2. They have an option of paying an extra $13 to get the disk. Should I just do that and wait for my disk to come in and then do a clean install?
Thanks for any help!
Vice President - Low Output 4 Cylinder Jeep Club
'98 2.5L - RC 2.5 - 33's - Beach Cruiser
"Aerodynamics are for people who can't build engines" - Enzo Ferrari
Stoked99 is offline
post #2 of 31 Old 01-20-2010, 08:07 PM
tjwoo
tjwoo's Avatar
Windows website has full instructions on how to do a full install via download. I did mine via download, it's just a tiny bit more complicated to do it this way.
Download it , download the bootdisk maker(via windows website), make a bootdisk on to a dvd or flash drive(4gb+). Remember to write down the key. and voila.
The flash drive will have to be formatted so, make sure you back up all the things on the flash drive before you do so.
tjwoo is offline
post #3 of 31 Old 01-20-2010, 08:11 PM
Chris_Walker
Chris_Walker's Avatar
1988 XJ Cherokee
You can do a clean install with the upgrade disc. If for some reason the downloaded version doesn't work like that, I have an image you can burn to a DVD, or I could mail you a disc.
Chris_Walker is offline
post #4 of 31 Old 01-20-2010, 08:13 PM
the88thpianoman
2003 WJ
Too bad you missed out on them selling it for $29.95, they did that up till January 5th.
You WILL need the disk to upgrade from 32 bit to 64 bit. I ran into this a couple weeks ago doing the same thing from 32 bit XP to 64 bit 7.
Now, they do offer you the option of downloading a .ISO file, which is the disk image that you can burn to a blank DVD, but I really recommend getting the actual windows disk. Back up everything you need off your hard drive, put in the install disk, restart your computer, and boot from the disk. It'll detect that you already have windows (which is necessary for your upgrade key to work), and begin a clean install to 64 bit.
You will not be able to go from 32 bit to 64 bit with the .EXE download, so make sure you use the .ISO if you're going to just go with the download. But again, the actual windows disk for the extra $13 eliminates the possibility of a damaged download or disk burn, so I would go with that.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #5 of 31 Old 01-20-2010, 08:19 PM Thread Starter
Stoked99
Considering I have next to no computer skills, it sounds like my best bet is just to spend an extra $13 to get the disk, correct?
and yeah 88thpianoman, I'm pretty bummed I missed that $30 deal. Oh well.
Stoked99 is offline
post #6 of 31 Old 01-20-2010, 08:30 PM
the88thpianoman
2003 WJ
Definitely get the disk, then. Also when two years down the road you need to reinstall or boot from the disk or do anything else that requires it, you have the disk already.
When you purchase it, they will email you the product key. They do not give you a product key with the disk. Do yourself a favor and write the product key on the disk sleeve. You will more than likely eventually need it.
post #7 of 31 Old 01-20-2010, 09:15 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
The other issues are drivers with 64 bit upgrade, unless all your printers, scanners etc are fairly new and drivers are available. Then you need an email program since none is bundled with WIN7.
I just did a WIN7 64bit install on my desk top PC. I should have went with the 32bit version. FWIW I bought it from Newegg ($104.99) and waited for the disc to arrive in the mail.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #8 of 31 Old 01-20-2010, 09:17 PM Thread Starter
Stoked99
My printer is fairly new so I think it will work. Why do you say you should have done 32 bit?
Stoked99 is offline
post #9 of 31 Old 01-20-2010, 09:44 PM
PhilipJ
PhilipJ's Avatar
His hardware probably wasn't up to snuff or it didn't have adequate 64-bit driver support (mfg's fault, not the OS's). Sometimes even big-name companies are extremely lazy in writing 64-bit drivers and even then they usually never make it past beta stage. If you are building your own system these days, there's no reason not to go 64-bit. RAM is stupidly cheap so 4GB should be your minimum and even multi-core CPU's are reasonably priced for the obscene amounts of workload they can handle. Try doing that in a 32-bit environment and you're going to hit a performance ceiling much sooner.
I built my current 64-bit system around x64 Vista two years ago and it still destroys anything I can throw at it.
PhilipJ is offline
post #10 of 31 Old 01-20-2010, 10:02 PM
KINGJB
how does everyone like windows 7? I want to do a clean install of it on my laptop over the summer.
Build Thread:
KINGJB is offline
post #11 of 31 Old 01-20-2010, 10:13 PM
TheDustMan
I have to say I like Windows 7 WAAYYY better than Vista. I like the way it looks too. Its clean, simple. And it has alot of customizable options if you can find where they put everything.
There is a learning curve associated with it, but once you get used to it you'll find that it works better. It seems faster, and it also has better support for the future of nonvolatile storage: solid state disks.
I have 0 regrets about moving from Vista to it. And if I had XP, I would have moved from it to 7 in a heartbeat. I've been running it since it was available in stores (EDIT: Actually, since it was a RC) and have yet to experience a BSOD. It has alot of cool little features too. For instance, instead of having a "Recent Documents" list in your start menu like in XP and Vista, if you have any recently used programs (which you will if your messing with various documents) it will show a little arrow next to the program name in the start menu and you can click that arrow and it will show all of the documents you have opened recently with that program. And you can open them from there too. Mine doesn't seem to be doing it at the moment though... I think I turned something off and now it won't do it, hahaha.
I like it much better than Vista, it feels faster, cleaner.
TheDustMan is offline
post #12 of 31 Old 01-20-2010, 10:13 PM
tjwoo
tjwoo's Avatar
Windows wise, very impressive. I never had vista so I can't say much about transition from there. I had the beta win7 (ultimate) since early last year, and release since well release (professional).
Simple, fast, customizable and generally unbogged. I'm sure crashes and bugs are to come, but so far so good.
tjwoo is offline
post #13 of 31 Old 01-20-2010, 11:23 PM
igrok
Windows 7 is the best operating system to come out of Redmond in my opinion. The 64bit version is faster, but harder to find drivers for everything.
It's almost good enough to keep me from booting into my Linux partition... NOT!
Common sense is surprisingly, not that common.
igrok is offline
post #14 of 31 Old 01-21-2010, 12:26 AM
jumbojeepman
1976 CJ7
I'm starting my install right now. XP to Win7x64. I got the upgrade disk from Newegg.
jumbojeepman is offline
post #15 of 31 Old 01-21-2010, 12:43 AM
tjwoo
tjwoo's Avatar
hmm? you bought the upgrade disk when you're going from XP to 7?
tjwoo is offline
windows 7 upgrade wont take mayor_bloom General Discussion 12 01-01-2010 03:37 PM
Bye Bye Windows XJLI General Discussion 8 11-05-2008 01:07 PM
Windows 95? XabuJr General Discussion 19 02-23-2008 11:11 PM
Windows XP help jtpaintball70 General Discussion 13 08-14-2006 08:23 PM
Windows Update make me log on to Windows FlyersFan2009 General Discussion 11 11-29-2005 06:04 PM
