> General
> General Discussion
What will work?(lossening up a frozen engine)
04-22-2009, 12:20 AM
#31
seriously, that stuff is amazing i use it in my mustang (crankcase and fuel tank) and it makes it run smooth as glass
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
04-22-2009, 12:21 AM
#32
have to see about it atr the hardware store, ive seen it there befor.
Eppur si muove
Originally Posted by Z0NAJEEP
With more stupid comments? Two retards don't make a right.
04-22-2009, 12:22 AM
#33
go to auto zone or shucks or oreillys or somewhere like that they always have it
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
04-22-2009, 12:28 AM
#34
Originally Posted by AngryLeprachaun
seriously, that stuff is amazing i use it in my ****tang (crankcase and fuel tank) and it makes it run smooth as a Chevy.
I'd really wish that I would grow some balls and drop in a Chevy motor into my POS Ford so I could get some HP outta her
Zombie Hunters member #4
Eric
04-22-2009, 12:29 AM
#35
Originally Posted by f3arn0FJ
keep this **** outta my thrad.
Eppur si muove
04-22-2009, 12:31 AM
#36
Originally Posted by Comanche
keep this **** outta my ***.
You didn't say please! Now bend over!!!
Eric
04-22-2009, 12:34 AM
#37
( please keep my more or less tech thread free of The *** rape posts, Kthxby.)
Eppur si muove
04-22-2009, 07:04 AM
#38
Youll need more than a 20 sec burst of penetrant. Grab a funnel and fill 'er up. Use some care with using the crank pulley bolt to unstuck an engine, rounding that one off is about the last thing you want to do at this point.
Again, you can pretty safely run it down a hill or pull it with a truck and let the clutch up to try and turn it that way.
04-22-2009, 09:52 AM
#39
www.lp.org
Fill the cylinders with penetrating oil. Let it sit for a day or two. With the plugs out, tow it up to about 35 mph, put it in 1st gear and dump the clutch. Keep pulling until you smell clutch burning.
Derpy Hooves for President in 2012
04-22-2009, 12:57 PM
#40
JF Administrator, eh?
If you can get the valve-cover off and change the oil-filter (I believe you stated it was an I6 engine), drain the engine oil out and pour slowly ATF (Automatic Transmission Fluid) over the whole top (all 4 litres or 1 gallon) till the oil-pan is "full".
Take another container of ATF and funnel it into each cylinder through the spark-plug holes till it pours out. Cap with a cork.
Wait 1 week.
Attempt to turn the crank by hand (12" to 16" breaker bar). If no turn - wait another week. Only attempt once a week (say on a Saturday morning) to turn the crank.
The cork is to allow pressure to blow-off without letting debris (bugs, moisture, etc) in while waiting for the ATF to do its job.
Alternative to ATF is diesel fuel.
Good luck on this and let us know.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies- From street to trail, '88 YJ on 38" tires does it all well
- Silver 2006 TJ Unlimited, zombie ready as the daily-driver
- a Kawasaki KLR650 DualSport bike
04-23-2009, 11:54 PM
#41
Removeing the oil filter wont work, it has the "can" style one with the replaceable filter insert.
Oil filter
and here is the engine.( my camera sucks, so every thing in full sun looks yellow)
I will try Diesel eventualy.
Eppur si muove
04-24-2009, 12:47 AM
#42
If you're going to pull it or push it down a hill, don't dump the clutch in first, there's too much resistance.
Do it in 4th, you'll have more mechanical advantage.
04-24-2009, 07:07 AM
#43
All I can see with the push and dump method is parts flying everywhere or a fried clutch.
-Ross
2007 Duramax 2500 Daily Work Horse
1994 Civic 2dr EX 5MT gas sipping Weekend cruiser
2002 TJ Sport 4.0 HO (Has some goodies) Weekend play toy
1987 Coleman Columbia
04-24-2009, 07:15 AM
#44
Busted crank in the making.
http://<b><font color="Red"><font si...nt></font></b>
Burrell's
Originally Posted by BIGRED99
I really have nothing in common with majority of you losers to be honest with you, is there an avator in here??? I would love to be deleted from Jeepforum as I drive an Audi now. Thank you and goodbye...
04-24-2009, 07:58 AM
#45
I prefer the nicer way.
"weakest link finder"
-Ross
