04-16-2009, 07:14 PM
#1
What will work?(lossening up a frozen engine)
I've tryed Penetrateing oil and it dient work to well, or so it seems. I need to know what might work.
If it matters it's a '63 toyota FJ-40 with the I6.
thanks!
Eppur si muove
Originally Posted by Z0NAJEEP
With more stupid comments? Two retards don't make a right.
04-16-2009, 07:28 PM
#2
Good luck, I left the plugs out of a gm I6 once and a few weeks later I couldn't get it to budge.
I basically filled all the cylinders with blaster and waited, then try to use a bar to turn the flywheel. No go.
I ended up junking it.
I can't bear the thought of losing, I dread the attention winning brings
Originally Posted by northjeep
4.2 has 0.2 more!
04-16-2009, 07:32 PM
#3
Might have to pull the head and help the pistons out with a block of wood and a rubber mallot.
-Ross
2007 Duramax 2500 Daily Work Horse
1994 Civic 2dr EX 5MT gas sipping Weekend cruiser
2002 TJ Sport 4.0 HO (Has some goodies) Weekend play toy
1987 Coleman Columbia
#4
Thats comforting, this one has been setting sence 2000, with the plugs in the engine.
And a new engine is Over $2000.
Eppur si muove
04-16-2009, 07:34 PM
#5
havent striped it down much, right now I jsut want to see if i can get away with not tearing it down.
Though things dont rust very fast here so I might get lucky(low humidity most of the year and little rain)
Eppur si muove
04-16-2009, 07:36 PM
#6
Try soaking them, and then taking the oil pan off and beating them with a block from the bottom. It might help you just enough.
4.2 has 0.2 more!
04-16-2009, 07:37 PM
#7
Marvel mystery oil, let it soak
#8
Thanks for the help.
Eppur si muove
04-16-2009, 07:38 PM
#9
Interesting enough, I found a old metal can(empty) of the stuff in the back of it.
Eppur si muove
04-16-2009, 07:40 PM
#10
If you can get the head on (if its off) pour kerosene in every little crack and crevice that might think about touching the cylinders. let it sit for a week or 2 and use a cheater bar to crack it loose. My friend and I did that to a 454 that he was putting in his nova. Got the engine for free because it was siezed. He went on to build it and run 10.2 at the local track.
04-16-2009, 07:54 PM
#11
Web Wanker
Diesel fuel poured down the spark plug holes. Let it soak for a while. Breaks it loose and the oil in it will help keep from tearing it up further when you get it to break loose and start moving.
The Final Salute
EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun!
We've idiot proofed the world... now its full of idiots. - Spiritof76
You will truly be the same today as you will be five years from now, except for two things, the people you meet and the books you read. Charles E. Jones
I think I'll add some memorable quotes. blah blah blah..... FPKites
Trying to understand some people, is like trying to pick up a turd by the clean side.
04-16-2009, 07:55 PM
#12
It's in one piece at the moment, havent torn it down more than takeing the sparkplugs out.
Eppur si muove
04-16-2009, 07:56 PM
#13
i would like to hear the outcome of this... so let us know. i like hearing tips and tricks.
04-16-2009, 08:45 PM
#14
We had an old Moline M That had froze up. We pulled the plugs and filled cylinders with wd 40 and in take manifold and exasht manifold with it too. We drained the oil and filled pan completely with diesel and wait 1 month drained oil pan and puled plugs and turned over engine with w breaker bar. Keep in mind this engine was froze up for years and pb blaster was not even made yet
04-16-2009, 10:03 PM
#15
that sounds like it might work.
Eppur si muove
