What should I do? Transfer Case Problems! - JeepForum.com
post #1 of 7 Old 06-29-2001, 09:31 AM Thread Starter
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
In addition to a cracked rear case to my np231, which has now been welded, the bearing retainer for the rear shaft is cracked around the bearing, and the synchronizer is screwed up!
Here are my choices - -
1) Rebuild
2) Junk Yard replace with a 231
3) New/Rebuilt 231 with a sye
or go for it all with
4) Atlas II twin stick w/gear reduction
I'm leaning toward 3 or 4, with the idea that a Atlas will help my overall gearing and power since I'm still running stock ring and pinion with my 89' yj - 4.2 - 5sp. - 31" tires - 2 1/2" rancho lift.
What's your opinion guys? I'll be deciding soon!!!! Like probably today! Help!!
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #2 of 7 Old 06-29-2001, 09:38 AM
93YJ
The best thing I have ever bought was an Atlas II. Can't go wrong with that!
Jay
www.txtrailriders.com
93YJ is offline
post #3 of 7 Old 06-29-2001, 10:09 AM Thread Starter
FLHT_FXRS_YJ
What's involved with the swap? New driveshafts? Any problems?
How low of gear reduction should I go if I want to help my stock gearing? I use my yj mostly as a summer daily driver, pull boats and hoists out of lakes, & play in the sand and mud. I have never been on rocks and I don't think I really need a rockcrawler.
post #4 of 7 Old 06-29-2001, 01:13 PM
osburn
osburn's Avatar
The Atlas is not going to be any different on the street you realize? It's high range is the same as the 231, 1:1. You have three choices on the low though. 4.3:1, 3.8:1 and the new 3:1. Your 231 has a 2.7:1. The new Atlas 3:1 is for the guys that aren't looking to get any lower, but want the strength you get with the Atlas.
Yes, you will have to modify your driveshafts. One, if you didn't have a SYE in your old 231, you'll now have a different type of driveshaft. Two, even if you did have a SYE, the Atlas is a couple of inches longer than the 231. So the rear shaft needs to be shortened and the front possibly lengthened.
Matt Osburn
Score 1032
osburn is offline
post #5 of 7 Old 06-29-2001, 07:17 PM Thread Starter
FLHT_FXRS_YJ
I found a new NP231HD with SYE already on for $750 at JB Conversions. The new driveshaft and cv coupler for $290. How's that sound price wise? Anybody know of any place else I can check?
post #6 of 7 Old 06-30-2001, 12:12 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Cheapest:
- NP231 out of a wrecked Jeep and do the SYE (strong enough for what you are doing now)
Strongest:
Atlas II
It all depends on what you plan to do. The NP231 is a fairly strong T-case for a stock / slightly modified beast .. and with a decent (not amazing) low range .. it should do alright
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #7 of 7 Old 06-30-2001, 10:16 AM Thread Starter
FLHT_FXRS_YJ
Thanks for the info guys - now I guess I just have to decide what to do and then get it done before to long!
Atlas 4sp transfer case Reelm n Rubi General Discussion 3 06-19-2013 12:13 PM
Transfer case service.. DIY or pay $300.00 SpeedyCat3 General Discussion 8 09-14-2007 09:29 PM
Transfer Case maintaince POLBOSS General Discussion 14 09-14-2007 07:57 PM
Transfer case giveaway mdm General Discussion 2 12-27-2006 02:55 PM
new transfer case dawgates General Discussion 9 06-17-2005 11:27 PM
