What causes a tire to do this? - JeepForum.com
Go Back JeepForum.com > General > General Discussion > What causes a tire to do this?
Ruffstuff Axle Simple Swap Kit!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-10-2014, 01:42 PM   #1
JeepPirate
I was wondering if any of you have experienced anything like this? The tires are goodyear at/s with about 10k miles on them. They are a matching set with a build date of mid 2011 on all 4. I had no noticeable problems when I left work, then on the way home with the cruise set at 65mph, I blew the right rear. I know its a little hard to tell from the pic, but there are two different sections of the sidewall completely gone. I figured they most be dry rotted on the inside but the tire shop that replaced it said it looked fine with respect to dry rot and couldnt figure out why this happened? I had the one that blew replaced with a new goodyear at/s with build date of late 2014. Now I'm just curious about the other three because I certainly dont want one of the fronts to do this. The tires are on a crew cab 2006 f-150 and are 265 70 17. They are also religiously monitored and kept between 30-35 psi.
JeepPirate is offline   Reply With Quote Quick reply to this message
Unread 12-10-2014, 01:54 PM   #2
JeepPirate
I also should probably mention the truck had nothing in the bed and I wasnt pulling a trailer. It was just me in the truck
Unread 12-10-2014, 03:11 PM   #3
vadslram
Were you running on low pressure? it looks like the sidewall delaminated and that usually comes from being overheated.
Another possibility is that you damaged the sidewall on the trail and the highway flexing just made it go.
vadslram is offline   Reply With Quote Quick reply to this message
Unread 12-10-2014, 03:59 PM   #4
TimV
30-35psi sounds low for that truck. What does the door sticker recommend for psi?
My old ranger took 35 psi. My F250 is 60/70 psi. I'd guess yours requires somewhere in between.
It's not an addiction. It's a way of life.
TimV is online now   Reply With Quote Quick reply to this message
Unread 12-10-2014, 04:10 PM   #5
JeepPirate
The door sticker reads 35psi cold. I could always raise it to 40, but I wouldnt have thought that even if it was 30psi that would have caused such a dramatic failure.
Unread 12-10-2014, 05:37 PM   #6
TexanTJ
Uncensored & Honest
TexanTJ's Avatar
2014 JK Wrangler
makes me wonder if the tire had ever been driven at low pressure. Even if they visually look fine, there can be hidden damage within the sidewall that can manifest itself as a failure such as this later on down the road.
2014 JKU Sport - Wife's Mall Crawler on 35s
1999 F250 7.3 - KT Performance Tuned TS 5-Pos - 1/4 Million Miles and Counting
"I am not going to censor myself to comfort your ignorance."
TexanTJ is offline   Reply With Quote Quick reply to this message
Unread 12-10-2014, 06:22 PM   #7
Ironhead
or it could have been a bad tire, it happens
Ironhead is offline   Reply With Quote Quick reply to this message
Unread 12-10-2014, 06:57 PM   #8
bobjp
I'd say it was just a defective tire.
97 TJ sport.
bobjp is offline   Reply With Quote Quick reply to this message
Unread 12-10-2014, 09:02 PM   #9
technologic80
2005 WK
Been there, done that. Too many fat chicks in truck at once.
Next time make the chubby redhead sit in the front, put the fat brunette in the back. Works every time. Weight differentiation, you know??
technologic80 is offline   Reply With Quote Quick reply to this message
Unread 12-10-2014, 11:00 PM   #10
ScruffMcGruff
Did you make sure you put the "winter air" in the tire before it got cold?
What makes hearing children’s laughter scary?
They’re giggling because they set something on fire.
ScruffMcGruff is offline   Reply With Quote Quick reply to this message
Unread 12-11-2014, 08:37 AM   #11
vindicated
Did you miss me?
vindicated's Avatar
Please see... http://www.jeepforum.com/forum/f7/ca...urnout-540596/
This is how this happens. HTH
Originally Posted by bradthebard
Vin's so hard core, he drinks the whole jug of STFU and then has a three hour conversation about it.
vindicated is offline   Reply With Quote Quick reply to this message
Unread 12-11-2014, 09:13 PM   #12
TSEJEEPERS
I would say it was probably the Ford emblem. They are hard on tires.
Yea I work for Firestone.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote Quick reply to this message
Unread 12-12-2014, 04:40 PM   #13
Scrmngchicken
Tires are cured with heat, and naturally heat will also degrade them. If I were to wager what happened, my money will go towards a puncture. Pick up a nail, centrifugal force throws it out and you have a steady leaker. And as the air escapes, heat builds up. When the temperature becomes critical, the tire gives out.
Scrmngchicken is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 05:41 PM   #14
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
The simple term is "run flat".
Mark
Smoke em if you got em!
Click here
Mobile_Homie is offline   Reply With Quote Quick reply to this message
Unread 12-17-2014, 06:16 PM   #15
chris142
That tire was driven flat for quite a while.
chris142 is offline   Reply With Quote Quick reply to this message
