#31 | |
Northman
In my rugby days of yore, we used to spray it on our joints along with using DMSO many moons ago.
Uncle Willy, The InnKeeper #3 06 Rubicon locked and loaded.... |
#32 |
Sucked water into your cylinders?
- Pull Plugs - Crank engine to spit water outer of cylinders - Suck excess water out of intake manifold - Spray a TON of WD-40 down the intake, and into each cylinder - Crank some more, and let the WD displace the water (also helps prevent cylinders from rusting up) - Once you are sure all water is gone, install plugs, try and start engine - It will be hard starting, and will run like crap for a few minutes - If all is well and you didn't hydro-lock a cylinder, you should be good - Change engine oil |
#33 |
A WD-40 soaked rag will clean the hull of a boat of ocean salt and/or that green crap that builds up.
Then it will act like sex wax the next time you are on the water. ![]()
Male voice: For more enjoyment and greater efficiency, consumption is being standardized. |
#34 |
Do it right or not at all
![]() Join Date: Jan 2003
It has a number of uses but unfortunately, it's not even a so-so lubricant. What little lubrication ability it has quickly evaporates within a few days. And if you spray it over a previously well lubricated part, it will often rinse (WD-40 is technically a solvent) the old lube off and leave it worse off than it was.
It's great to chase water out of electrical connections (even the alternator) on the Jeep and that's all use it for.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#35 |
www.lp.org
It works poorly as a 'personal lubricant'.
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? " Roger Waters |
#36 | |
I'm tired
The Final Salute EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun! We've idiot proofed the world... now its full of idiots. - Spiritof76 You will truly be the same today as you will be five years from now, except for two things... ...the people you meet and the books you read. Charles E. Jones |
#37 |
WD 40 is mainly kerosene isnt it?
I have a can of it in the shed but rarely have a use for it. |
#38 |
lol... get it.... avatar!
I KNEW IT!!!!
I knew jerry would have posted his anti wd40 post.... I KNEW IT!!!!! |
#39 |
Wasp killer
wd 40+flame=enjoyment
l_JEEP_l (OlllllllO) Marine Corps Jeep Club Member #4 |
#40 |
• Lubricates manifold heat control valve
• Helps clean sidewalls on tires • Removes tar from chassis • Removes decals from windows and bumper • Removes insects from front grill • Cleans motorcycle chains • Removes grease from clothing • Removes adhesive tape without damaging factory paint • Helps hone cylinder walls • Protects corrosion-sensitive areas of car • Prevents corrosion of spark plug cables • Shines motorcycle finish • Removes sludge from outside engine block • Removes asphalt from trucks • Cleans grime from engines • Cleans and protects chrome on cars • Helps remove brake dust from wheels • Restores shine on classic cars • Keeps hitch locks rust-free • Cleans road oil from rocker panels • Cleans and protects aluminum rims • Shines car tires • Cleans marks from rubber surfaces • Cleans rusty bolts • Keeps brake levers clean on motorcycles • Removes greasy fingerprints from car interior • Lubricates key holes • Removes silly putty stuck on car seats • Lubricates trunk latch • Spray on snow chains to keep from rusting • Removes roof mastics from tools • Removes tree sap • Keeps car battery terminals clean • Cleans lock nuts around gate valves • Unsticks car door during cold weather • Lubricates car antenna • Helps remove stubborn rust from tow ball • Cleans and protects power antennas • Cleans white wall tires • Cleans buildup from wood trim • Removes asphalt from tools • Lubricates tire air knobs • Removes glue from leather • Lubricates valves on fire trucks • Cleans pigeon droppings from cars • Lubricates rusted fasteners • Protects most vinyl surfaces • Lubricates license plate bolts and screws • Tones down shine of polyurethane • Lubricates oil filter gasket • Keeps tire jack working smoothly • Cleans reusable air filter elements • Maintains dashboard • Removes melted crayon from upholstery • Cleans and protects rubber boots of drive axles on front-wheel drive vehicles • Keeps rubber door weather gaskets soft and pliable • Cleans PVC valves • Keeps windshield wipers rust-free • Coat truck bed before installing bed liner to make removal easier • Removes rust from side view mirror • Cleans grease from rubber hoses • Shines and protects bed liner • Cleans gunk from travel trailer siding • Lubricates sunroof crank • Cleans and protects rear view mirror balls and sockets • Lubricates child safety seat buckles • Lubricates socket wrench • Cleans battery chargers • Lubricates door latch to gas cap • Displaces moisture from spark plug wires
-Andrew Low Output 4 Cylinder Jeep Club member #59 [QUOTE=Grewe02]No such thing. Eat **** and die.[/QUOTE] lifted with some extra's ......sold |
#41 | |
You come back...one year!
I love how this thread was mainly serious while it was in TJ tech but as soon as it gets moved to GD, the first post is this. ![]() |
#42 |
Frees up stuck econo-plugs.
#43 |
BUILT. NOT BOUGHT.
Those of you with stainless steel kitchen appliances.....
spray a very light coat on the appliance and rub it very well witha soft cloth. works quick and easy once you get the hang of how much to spray! and wiping fingerprints off is easier than ever once you start using it -Erik <--- sprays it all over his SS appliances!
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS! |
#44 |
It dos a decent job of stoping rust.
XJ Body Lift Owner #2 High threshold to pain Rustys 4.5 33 12.50's Pacer 15x10 soft 8's |
#45 |
Palmetto Tree Stickered Black Jeep Owners Club, Hunting Chapter Member #1110010 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
