Water on garage floor from snow-melt. What to do? - JeepForum.com
post #1 of 36 Old 12-16-2010, 02:09 PM Thread Starter
CNY
Caught ridin' dirty
Two-car garage. Cars pull in with snow, fenderbergs, wet stuff.
Snow melts, floor covers in water. No floor drain, and the concrete has random lowspots, so water pools in several spots, but doesn't run to the door.
Last year, I did a lot of squeegeeing. This year, I glued pressure-treated 1x2's to the floor (creating a containment wall), and sealed the wood with good sealant.
The water now stays within the borders I created, but I have to shop-vac GALLONS of water every day, along with still squeegeeeing towards door.
Those of you who park in a garage, what have you done to deal with this?
I was thinking of cutting grooves in the concrete, that lead to the door. I don't know enough about construction to know whether that would turn into a very bad idea (it certainly would lead to ice out in the driveway).
(We're talking about a LOT of water here. One mudflap-iceberg can contain almost a gallon of water)
CNY is offline
post #2 of 36 Old 12-16-2010, 02:11 PM
Gina
have you looked into installing a pump, the type people run in their basements for flooding?..the proper name escapes me right now..On a heavy round of vicodin,. hahah
Gina is offline
post #3 of 36 Old 12-16-2010, 02:13 PM
Cuder
Teach your Jeep to do this.
YouTube - Jeep: Shake
My Build Thread:
Cuder is offline
post #4 of 36 Old 12-16-2010, 02:18 PM
tjchad04
it's a garage, how is water effecting it? does your garage get below freezing? i've never seen one with a drain, the water in mine just evaporates.
tjchad04 is offline
post #5 of 36 Old 12-16-2010, 02:19 PM Thread Starter
CNY
Caught ridin' dirty
A pump might work, the problem would be.. where to dig the hole. There are 3 main pooling locations, each one te or so feet from eachother.
CNY is offline
post #6 of 36 Old 12-16-2010, 02:20 PM
amike_321
If possible you can run hot water to a garden hose and spray off the chunks if ice/snow while the cars are still outside?
amike_321 is offline
post #7 of 36 Old 12-16-2010, 02:22 PM
chumpmann
That is why Garages have concrete floors and are supposed to have a 4" lip at the walls and at the front.
Should dry up pretty good....
"Never trust quotes on the internet" - Bejamin Franklin
ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
Other Jeeps...
1994 YJ - 2.5" RC lift, 31x10.5 BFG AT
Hers - '07 XK
chumpmann is offline
post #8 of 36 Old 12-16-2010, 02:26 PM
sandandson
Get some concrete or portland mix and fill in the low spots.
sandandson is offline
post #9 of 36 Old 12-16-2010, 02:29 PM
yellow_xj
You could try this LEVELEX Portland Cement-Based, Self-Leveling, Polymer-Modified Underlayment - L&M Construction Chemicals
01,4.0 W/Upgraded Injectors & Bored Throttle Body,AW4,NP231,D30 W/RC CA Drop,C8.25 W/Aussie Locker & Junkyard Disc Conversion,6" lift on 33X12.5X15.
Yellow Jeep Club member # 16
Jeeps dont die they get rebuilt bigger and stronger, like the 6 million dollar man!
yellow_xj is offline
post #10 of 36 Old 12-16-2010, 02:58 PM
MAMMOTH
Wooly Member
MAMMOTH's Avatar
Do what I do.
Park it outside.
2004 TJ Rubicon - 3" lift, 1" BL, Brown Dog MML with Super brackets, 33's, Warn Winch, VanCo BBK - (Thanks MisfitSeven), IronRock tierod, Ten Factory shafts.
Future upgrades - Too many to list
1999 XJ - DD with 228k
2007 JK Unlimited - The wife's ride.
MAMMOTH is offline
post #11 of 36 Old 12-16-2010, 03:02 PM
ajf1994
Mine evaporates even when it is in the negatives. It's an attached garage... Does that tell you inefficient my home is insulated? It's only 12 years old too.
-SupportOurTroops-
High School Jeepers #361
Parrothead Jeep Club #46
37,xxx Miles
Originally Posted by XJ-Tim View Post
my welds look like popcorn with sprinkles.
Originally Posted by Benjamin Franklin
Beer is proof that God loves us and wants us to be happy.
ajf1994 is offline
post #12 of 36 Old 12-16-2010, 03:03 PM
xxxflhrci
xxxflhrci's Avatar
The pump is a sump pump....Definitely not what you want to get into just to get a few gallons of water outta your garage.
Personally, I've never heard of anybody doing anything much about the water. They just let it dry on it's own. I agree with the guy above. I'd just park outside. You car will be better for it by not pulling it in as far as rust prevention goes.
xxxflhrci is offline
post #13 of 36 Old 12-16-2010, 03:07 PM
96_XJ_Sport
what about a larger dehumidfier with a drain hose that runs outside instead of a tank?
Just Empties Every Pocket - 96 XJ Sport,- 4.0 H.O. - 235/75/15 General Grabber AT2's - Black D Windows - Hella 500FF Driving Lights - RC 4.5 X-series
ΜΟΛΩΝ ΛΑΒΕ
96_XJ_Sport is offline
post #14 of 36 Old 12-16-2010, 03:12 PM
jeep161
2009 JK Wrangler
use the levelex then make a french drain !!!
jeep161 is offline
post #15 of 36 Old 12-16-2010, 03:13 PM
xxxflhrci
xxxflhrci's Avatar
Unless it's fairly warm in his garage, a dehumidifier will likely freeze up.
Garage Floor Paint 303_XJ General Discussion 8 10-02-2010 09:29 PM
Anybody ever epoxy their garage floor or know somebody who has? Xander General Discussion 9 10-12-2009 09:18 AM
Garage Floor Fred007 General Discussion 16 03-12-2009 09:28 PM
Garage Floor Coatings? shudog General Discussion 5 12-25-2005 07:45 AM
Garage Floor Coatings? myuserid General Discussion 11 12-20-2005 06:09 PM
