Quantcast trailer tire q's?? - JeepForum.com
Go Back JeepForum.com > General > General Discussion > trailer tire q's??
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 03-28-2010, 03:47 PM   #1
willyb8
willyb8's Avatar
trailer tire q's??
just bought a popup camper and it needs new tires, dryrotted. the ones on there are 5.30-12 load range C and max of 80psi. can/or should i go up to a load range D max psi 105psi? or will it be too bouncy and rough with that much pressure? i just figured i'd go up cuz of the higher weight rating. 1045 vs 1220/tire. the camper weighs 1500lbs.
91 YJ 4.0 HO,
3.5" BDS, 5/8 MORE Booms, 1" BL, MML
AA SYE & CV,
35" Maxxis Bighorn
Smittybilt XRC8 Winch,
8.8 W/Elocker, D30 W/Aussie
Genright tube fenders
willyb8 is offline   Reply With Quote
Old 03-28-2010, 04:39 PM   #2
RAZORBILL
That's mine, give it back
RAZORBILL's Avatar
2011
I don't think you would need to actually put 80 or 105 psi in the tires. That's just the max pressure the tire is rated for. My little boat trailer has 4.8x12 with 60 psi max, I run 'em at 50 psi (cold) and they seem fine. I'd probably just stick with the 5.3x12's and run 'em at 60psi. Then take it out and see how it handles and check for excess tire heat. If it handles fine and the tires are relatively cool your good.
That's my 2 cents anyway.
PS: Check the hubs, if the tires are shot chances are the previous owner didn't grease the hubs either.
"Do not burn yourselves out. Be as I am --- a relunctant enthusiast . . . a part-time crusader, a half-hearted fanatic. Save the other half for yourselves and your lives for pleasure and adventure. It is not enough to fight for the land; it is even more important to enjoy it. While you can. While it's still here. So get out there and hunt and fish and mess around with your friends, ramble out yonder and explore the forests, encounter the grizz, climb the mountains, bag the peaks, run the rivers, breath deep of that yet sweet and lucid air, sit quietly for a while and contemplate the precious stillness, that lovely mysterious and awesome space. Enjoy yourselves, keep your brain in your head and your head firmly attached to the body, the body active and alive, and I promise you this one sweet victory over our enemies, over those desk-bound people with their hearts in a safe deposit box and their eyes hypnotized by desk calculators. I promise you this: you will out live the bastards."
-Edward Abbey
Currently Jeepless...
Previously owned: 80 CJ-5, 97 TJ, 99 XJ, 95 YJ 10 JK Rubicon Unlimited
RAZORBILL is offline   Reply With Quote
Old 03-28-2010, 05:12 PM   #3
willyb8
willyb8's Avatar
should i go with the load D or stick with the Load C. both are 5.30-12 i think its like $10 difference
91 YJ 4.0 HO,
AA SYE & CV,
35" Maxxis Bighorn
Old 03-28-2010, 06:01 PM   #4
Zeep
Zeep's Avatar
Chances are the C rating will be more than sufficient. Unless you plan to add a half ton of gear to your rig.
What are you using for a tow rig? Does the trailer have brakes? Common sense rules the day when towing!!
JEEP THE AR-15 OF THE AUTOMOTIVE WORLD
Zeep is offline   Reply With Quote
Old 03-28-2010, 06:30 PM   #5
captainauti
scallywag
captainauti's Avatar
id go with 31's. http://www.jeepforum.com/forum/f68/who-has-lifted-pop-up-tent-trailer-619508/
check that out. i gave my brother my old starcraft like the last pic. my new flagstaff is getting a lift this spring.
_______________________
Capt. Nate
aka Scallywag
95 yj 4.3 vortec csfi, 4l60e/np231cj
2007 Lincoln MKX 3.5l
2011 F150 4x4 5.0 supercrew
captainauti is offline   Reply With Quote
Glock Forum
