Tools Everybody Should Have. - Page 2 - JeepForum.com
post #16 of 36 Old 12-10-2012, 09:54 PM
jrallen
This is all I can think of
jrallen is offline
post #17 of 36 Old 12-11-2012, 06:38 AM
vadslram
Attachment 523038
Add vice grips and a BFH and you have the complete tool kit
vadslram is offline
post #18 of 36 Old 12-11-2012, 06:54 AM
YJames90
YJames90's Avatar
Pickle fork !!! someone stole mine And I needed one last night. I was pissed!!
My 2.5 to 4.3 swap thread
YJames90 is offline
post #19 of 36 Old 12-11-2012, 07:03 AM
firefighter315
Good call. Have you ever used the impact variety for your air hammer? I am going to grab one the next time I run across a good deal. Seems like a no-brainer.
My YJ Build Thread
firefighter315 is offline
post #20 of 36 Old 12-11-2012, 08:00 AM
bravobravo
if you work on late model vehicles a factory scan tool is invaluable.
but if your not looking for that, you need an acurrate arm to swing that bfh or you'll hit the most expensive thing next to where you're aiming.
(dont ask how i know)
^ it made more sense in my head
removed for stirring the pot
bravobravo is offline
post #21 of 36 Old 12-11-2012, 08:43 AM
Xpress
Torx driver bits.
All about that unibody life.
Xpress is offline
post #22 of 36 Old 12-11-2012, 08:40 PM
TJJP77
TJJP77's Avatar
For me, the list includes: (in no particular order)
  • 1/4", 3/8" & 1/2" shallow and deep sockets in 6 and 12-point
  • Extensions in the three drive sizes and various lengths
  • Quality fine-tooth fixed-head ratchets
  • Quality fine-tooth flex or swivel head ratchets
  • Impact sockets
  • Impact wrench (air or electric)
  • Various allen and torx bits
  • 6-point combination box/open end wrenches
  • Ratcheting box wrenches
  • Offset box-end wrenches
  • Channel-lock type adjustable pliers
  • Vise-grip type pliers
  • Needlenose and standard pliers in various sizes
  • Convertible snap ring pliers
  • Adjustable (Crescent) wrenches
  • Pipe wrench
  • Quality screwdrivers in various sizes/lengths
  • Precision screwdrivers
  • Flare nut wrench set
  • O2 sensor socket
  • Digital Volt-Ohm Meter
  • Timing Light (if you have any older cars)
  • Compression tester
  • Self powered test lamp
  • 12-volt circuit tester
  • Soldering iron (butane powered is awesome!)
  • Wire crimpers/strippers
  • Automotive stethiscope
  • Vacuum tester/gauge (Mighty-Vac)
  • Vacuum plugs/caps
  • Quality torque wrenches (both in.-lb. and ft.-lb.)
  • Quality files and rasps
  • Cold chisels
  • Punches
  • Prybars
  • Bolt and stud removers
  • Rubber mallet
  • Dead-blow hammer
  • Small handheld sledge hammer
  • Ball-pein hammer
  • Conventional hammer
  • Flaring tool
  • Aviation snips
  • Brake spring pliers
  • Hose clamp pliers
  • Hose pinchers (to seal off heater hoses or vacuum lines)
  • Quality spark plug gapping tools (not the crappy spiral ramp type)
  • Feeler gauges
  • Oil filter wrenches
  • Measurement tools - i.e. digital caliper, micrometer, etc.
  • Dremel tool
  • Small handheld torch for occasional "persuasion" on rusty/tight parts
  • 1/2" corded drill (never seem to be able to depend on the cordless drills, but my corded model never fails)
  • Quality drill bits
Needless to say, I'm fairly self-sufficient automotive repair-wise...
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #23 of 36 Old 12-12-2012, 10:29 AM
bobjp
Cheater bar.
97 TJ sport.
bobjp is offline
post #24 of 36 Old 12-12-2012, 12:45 PM
bravobravo
no cheating allowed, real men use wd40 pliers and a long list of cuss words to get the job done.
slowly pushes cheater bar out of picture.
post #25 of 36 Old 12-12-2012, 01:32 PM
1stblack97ZJ
A set of ratchet wrenches.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #26 of 36 Old 12-12-2012, 02:04 PM
spward
All you need is a "cresent hammer" and a file.
Scott
spward is offline
post #27 of 36 Old 12-12-2012, 04:31 PM
TimV
Super glue to glue your finger back together after you fillet it open working on a project.
It's not an addiction. It's a way of life.
TimV is online now
post #28 of 36 Old 12-12-2012, 05:16 PM
jwhite207
I like those telescoping magnets, seems like i always drop a nut/bolt in a tight place. Good set of snap ring pliers is always helpful, don't use them often but I would be without a paddle if I didn't have them. Snap-On 3/8ths drive impact gun is nice, use it more then I give it credit for. I'm sure I will chime back in once I get some more.
give er sum
jwhite207 is offline
post #29 of 36 Old 12-12-2012, 06:57 PM
bravobravo
picks.
post #30 of 36 Old 12-12-2012, 07:15 PM
Tdog02
Torque wrenches
Mechanics beginner kit
Good tool box
Good lights
Impact
Floor jack and couple of stands
Good for most home projects, repairs, maintenance.
it is what it is except when its something else
Tdog02 is offline
