Quantcast TOOL DEFINITIONS: This is really funny... - JeepForum.com
Go Back JeepForum.com > General > General Discussion > TOOL DEFINITIONS: This is really funny...
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 09-25-2009, 09:47 AM   #1
andr3w
TOOL DEFINITIONS:
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest
and flings your beer across the room, denting the freshly-painted part
which you had carefully set in the corner where nothing could get to
it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere
under the workbench with the speed of light. Also removes fingerprints
and hard-earned calluses from fingers in about the time it takes you
to say, ''What the...''
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes until you die of old age.
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation
of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor
touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt
heads. If nothing else is available, they can also be used to transfer
intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the
conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various
flammable objects in your shop on fire. Also handy for igniting the
grease inside the wheel hub you want the bearing grease out of.
TABLE SAW: A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
after you have installed your new brake shoes, trapping the jack
handle firmly under the bumper..
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile
upward off of a trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters gained from using a 2X4
to try to lift an automobile off of a trapped hydraulic jack handle.
PHONE: Tool for calling your neighbor Chris to see if he has another
hydraulic floor jack.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any
known drill bit that snaps neatly off in bolt holes thereby ending any
possible future use.
BAND SAW: A large stationary power saw primarily used by most shops to
cut good aluminum sheet into smaller pieces that more easily fit into
the trash can after you cut on the inside edge of the line instead of
the outside.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength
of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that
inexplicably has an accurately machined screwdriver tip on the end
opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under
lids and for opening old-style paper-and-tin oil cans and splashing
oil on your shirt; but can also be used, as the name implies, to strip
out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
convert common slotted screws into non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate the most expensive parts
adjacent the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly
well on contents such as seats, vinyl records, liquids in plastic
bottles, collector magazines, refund checks, and rubber or plastic
parts. Especially useful for slicing work clothes, but only while
wearing them.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that
travels by hose to a Chicago Pneumatic impact wrench that grips rusty
suspension bolts last tightened 40 years ago by someone in Abingdon,
Oxfordshire and rounds them off.
****** TOOL: Any handy tool that you grab and throw across the garage
while yelling ''******'' at the top of your lungs. It is also, most
often, the next tool that you will need.
1992 YJ - "Heep of Faith" -- sold for parts
1995 Cherokee Country - 236,000 miles - Daily driver.
1997 TJ Sport - 99,000 miles - project
John 3:16, "For God so loved the world that He gave His only begotten son, so that whoever believes in Him will not perish but have eternal life."
andr3w is offline   Reply With Quote
Old 09-25-2009, 09:59 AM   #2
Fett
Mechanically Declined
Fett's Avatar
I have a few of those "******** tools". I had a ****** flashlight break on me last week. Momentum got the best of it.
99 TJ Sport I64L Manual 31x10.5 RE 3.5" Super Flex 1"BL 3.73 gears w/LockRite in front. Warrior Safari Rack.
"When you honestly believe you can compensate for lack of skill by doubling your efforts, there's no end to what you can't do". www.despair.com
|_
|T|
Fett is offline   Reply With Quote
Old 09-25-2009, 11:20 AM   #3
-Zona-
LMAO!!!!!!
Originally Posted by MrNate View Post
Zona and Cause. I'm halfway convinced they're the same person.
Originally Posted by cherrybomb05 View Post
Or Zona because he reminds me of charlie sheen
http://www.preparedsociety.com
-Zona- is offline   Reply With Quote
Old 09-25-2009, 11:55 AM   #4
GSU_DAVE
What about the Ineedatool... as in the one tool you need to finish your project that you are 4 hours into and don't have.
GSU_DAVE is offline   Reply With Quote
Old 09-25-2009, 12:15 PM   #5
iluvtruenos
Oh god, every single one of those is true.
I mean every single one.
My Jeep is a chick magnet with reverse polarity.
Rampant Pack of Retards group president.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline   Reply With Quote
Old 09-25-2009, 04:04 PM   #6
andr3w
here are few more i found:
Snap-On Gasket Scraper: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot.
Timing Light:A stroboscopic instrument for illuminating grease buildup on crankshaft pulleys.
Grease Gun: A messy tool for checking to see if your zerk fittings are still plugged with rust.
Old 09-25-2009, 04:08 PM   #7
ChickenOnAWire
totaly crawled!!!!
-[COLOR="Blue"]2000 TJ Sport lifted, tires, bumper, lights[/COLOR]-[COLOR="Red"]Sold[/COLOR]
-2000 WJ Limited Flowmaster Super 40 K&N CAI (more coming soon)
ChickenOnAWire is offline   Reply With Quote
Old 09-25-2009, 04:08 PM   #8
rokcrawler3203
1974 DJ
Man those are OLD! But still funny. I had a friend give me some of those on a piece of paper about 8 years ago.
"The road to success is dotted with many tempting parking spaces."
"Of course I keep my dishwater clean, it just looks like chocolate milk and lettuce when I'm done" --Chance; A fellow employee
NITECREW #245
rokcrawler3203 is offline   Reply With Quote
Old 09-25-2009, 04:14 PM   #9
andr3w
Sorry if you had seen them before. My dad found them and sent them to me.
Old 09-25-2009, 04:25 PM   #10
-Deepskyy-
Dangerous Hillbilly MA
-Deepskyy-'s Avatar
GOOSE NECK RATCHET: Tool designed by Satanic Communists that when used properly will fold when maximum torque is being applied, slamming knuckles into suspension parts and your head into the fender that you are working beneath.
One of my very favorite devices. I've thrown more goose neck ratchets in anger than any other tool at my disposal.
Are you finding the Jeep Forum helpful? Donate today!
"I never saw such fighting since God made me. The Americans fought like demons"
-Lt. General Charles, Earl Cornwallis after the battle of Guilford Courthouse NC
Originally Posted by Outatime05 View Post
Females are a dime-a-dozen. Jeeps are forever. Easy choice. Be indispensible or be gone. :wave:
Originally Posted by jeepdavetj View Post
We are Jeepforum. We can do the unthinkable. We are Jeep strong. And head stubborn. We are. JEEPFORUM.
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Red Jeep #543
-Deepskyy- is offline   Reply With Quote
Old 09-25-2009, 04:26 PM   #11
rokcrawler3203
1974 DJ
Yeah, but they're still pretty funny. You should see the ones with the cartoon pictures to go with them...
I can't find them though.
NITECREW #245
Old 09-25-2009, 04:29 PM   #12
9EEP
good stuff
9EEP is offline   Reply With Quote
Old 09-26-2009, 02:04 PM   #13
iluvtruenos
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid from a car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin", which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
Old 09-26-2009, 02:17 PM   #14
Mean Max
Mean Max's Avatar
Hmm....
http://www.jeepforum.com/forum/f7/tool-definitions-653924/
Otherwise, Really funny stuff!
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Mean Max is setting up his Jeep shop!
Picture history of my progress here.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Old 09-26-2009, 02:28 PM   #15
iluvtruenos
Originally Posted by Mean Max View Post
Hmm....
Max
Yeaaa......this one's better than yours.
Glock Forum
