Tom Woods' new u-joints - JeepForum.com
Go Back JeepForum.com > General > General Discussion > Tom Woods' new u-joints
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 02-13-2008, 05:46 PM   #1
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Anybody using them? They look pretty sweet. I'm going to either need to stretch my wheelbase or shove my motor into the radiator after the swap. Maybe these u-joints will let me prevent that?
http://www.4xshaft.com/index.html
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline   Reply With Quote Quick reply to this message
Unread 02-13-2008, 06:32 PM   #2
Tj_Justin
What swap?
they look beefy, any cheaper than CTM'S?
8.8 w/ lockrite
RE lift, 35" Mud Kings
98 Wrangler 4 banger
Tj_Justin is offline   Reply With Quote Quick reply to this message
Unread 02-13-2008, 06:55 PM   #3
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
They aren't really new. Nor are they much more durable than a spicer / CTM joint.
2000 Jeep XJ - Chopped / Locked
1997 Jeep XJ - Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Join the XJ Owners Club | Download the iMarn® iPhone App!
SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather!
Homepage | Jeepspace Group|Twitter!|Facebook
BeachinXJ is offline   Reply With Quote Quick reply to this message
Unread 02-13-2008, 07:16 PM   #4
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Well I'm not looking for durability. I'm looking for extreme driveline angle capability. LS1 + SM465 + Dana 300 = short driveshaft.
Andy, KD8EIA
Unread 02-13-2008, 08:18 PM   #5
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Don't even put Spicer and CTM in the same sentence where it comes to u-joints. That's like comparing a middle-weight to a super-heavyweight boxer. Neither Tom Wood's nor Spicer's u-joints are even close to being as strong as the nearly bulletproof CTM is. Night and day.
Getting Savvy...
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 02-13-2008, 09:56 PM   #6
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
I dunno. I've broken both equally. But you're right.
Unread 02-13-2008, 09:56 PM   #7
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
If you did some grinding on a shaft and stronger ujoint i am sure you could accomplish almost the same thing.
Unread 02-14-2008, 09:02 AM   #8
GrimJeeper91
Those zerks would be gone in about five minutes in the rocks (at least on the pinion end)...
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline   Reply With Quote Quick reply to this message
Unread 02-14-2008, 07:12 PM   #9
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
This is very true, I may have to look into some sort of option along this line.
Andy, KD8EIA
Unread 02-14-2008, 07:25 PM   #10
Tj_Justin
I would assume with that kinda equipment your also going to do a stretch, that should help a little bit.
Also, what axles are you running, Would my assumption of a 14 bolt rear and Hp D60 front be correct?
Maybe consider a 9" in the rear if your not going to huge, you could get a high pinion differential in the rear to help you out a bit more.
Wait a tick, What is tech doing in GD :flipoff:
8.8 w/ lockrite
Unread 02-14-2008, 09:21 PM   #11
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Yeah, I've still got the Dturdy and AMC 20 for now. I'm just going to DD it until I can afford a Hi9 and HP44. 35s will be my max me thinks.
Oh and it's in GD because there is better tech advice here.
Andy, KD8EIA
